This is a strange one..
I select a clip in Premiere and choose render in AE. I then modify, save the file in AE, close AE, go back to Premiere and the modified version is sitting pretty, no problems thus far. I save the file in Premiere, which in my experience is the above all must do task, and proceed to the next clip. I do the same procedure.. modify in AE, opens AE, proceed with modifications, save, go back to Premiere and there's the new replacement, no problems.. except.. the first clip I edited in AE has now been replace by the second one. So I have 2 identical AE compositions where I should have 2 different ones. Furthermore, when I quit Premiere and open the first AE composition independently in AE it too has now changed in to the second composition, EVEN THOUGH it was saved as a separate file. I can kind of understand what's happening, but how do I prevent this from happening again and what happens to the first composition I saved?
I'd trash your preferences and try again. http://blogs.adobe.com/genesisproject/2009/11/having_weird_behavior_wi th_an.html
Beyond that, when you do your second comp, make sure your first AE project (including the comp) is open.
Hope this helps,
Dennis
Addendum..
It worked the first time.
It didn't work the second time.
I'm beginning to think it's a version problem.
I'm not the only one finding annoying little faults since the install of 5.02.
Any ideas how to get around this?
I'm even taking the new files created in AE and importing them directly in to premiere. They show as originally edited in AE, but asa they are in Premiere they revert to the file previously edited, in appearance anyway.
And..
When I open the modified file in AE it is reported as linked to file X.
When I open the file that proceeds it in AE it is linked to file Y.
And the next one is reported as being linked to file Z.
But..
When I import all of these in to Premiere they are all labelled as linked to file Z.
Premiere replaces the former 2 edits with the latter even though they still exist as separate AE files, viewable in AE.
I've even saved them under different names, but Premiere still links them to the newest edit.
You said it might be a version problem? What version of AE? Confirm again your version of Pr from Help | About, please.
A series of screen shots would be helpful. Your AE project panel and one of the comps open in the timeline; your Pr project panel showing one of the AE comps selected; a Pr sequence open that contains one of the comps.
Please create a new test project from File | New and see if you can duplicate the problem. Use different files (not just renamed files) and a new AE project. That'll troubleshoot the possibility of a corrupted working project.
-Jeff
This is not a version problem. This annoying bug has been around since day one with Dynamic Link.
There are two ways around it.
1. Make sure you use the same AE "Project" with multiple compositions. A composition for each Dynamic Link. (Make sure compositions have unique names)
2. Make sure the project name and composition names are COMPLETELY different from the other projects.
Do NOT "save as" any AE projects from original ones to save time with new compositions. It will screw all your other Dynamic links up the minute you save it.
You can't even use names like "Project A or Project B. It has to be completely different or all your links will be saved back to your last one.
Tclark your answer was very helpful, but I was left a little confused.
So it's better to use 1 project with multiple compositions rather than several different projects?
I've been saving two different versions, project a and project b, reimporting the AE file and deleting the 5.0 folder in docs to work around this annoying issue. Long and tedious but it does work.
'Do NOT "save as" any AE projects from original ones' Not quite sure what you mean. They are clips from Premiere, not original AE files. Cold you explain plz.
Thx again for the valuable help all.
This is the first I've heard of it. And I've twisted DL upside down and sideways for several years now, and I have never encountered this issue.
Do you have reproducible steps I can try in new projects to see this bug in action?
This, to me, seems patently obvious. Are there places in the documentation for Pr and/or AE where some other method is given or suggested? If so, those entries may need to be corrected.
The only issue with Save As, or incrementing, that I have seen is one that is to be logically expected. If you link to a comp in Project_A from Pr, then work in Project_A in After Effects, then Save the current AE project as something like Project_A_01, all of your links in Pr still point to the old version, Project_A. You'd have to re-link all of the comp references in Pr to the new version of the AE project to get the changes to appear in Pr. Again, to me, that is expected behavior.
Any reproducible steps you can post would help.
-Jeff
When PP opens an initial link to AE, a new AE project is created. That project must be saved when you exit AE otherwise the work done in AE (ie, the contents of the dynamic link) will be lost. When you create subsequent dynamic links, AE will create a new project unless the original one remains open.
No matter the number of linking clips, it is always better to have them contained as separate compositions within one AE project rather than allowing AE to create a new project for each link - as that is not the best management of resources.
If you change the name of that AE project (save as), you will have to re-link the clip links from within PP.
It's the relinking that seems unnecessary to me. After the first time this happened I made sure to exit both programs when I'd finished and restart to try and avoid any link being made with the next clip I wanted to change in AE. If the clips have completely different names and the work done in AE is saved, I fail to see why Prem would automatically change the linked clip.
'That project must be saved when you exit AE otherwise the work done in AE' - Yes, I did that originally.
'If you change the name of that AE project (save as), you will have to re-link the clip links from within PP.' I did relink, but only after Prem connected the previous file to the new one. Plus I had to resave the new file in AE under a different name to stop Prem from replacing the previous clip with the new one.
'all of your links in Pr still point to the old version, Project_A. You'd have to re-link all of the comp references in Pr to the new version of the AE project to get the changes to appear in P' - the opposite is happening. Prem links the previously replaced clip withe new one, i.e clips A and B become clips B and B.
Relinking only becomes necessary if you have renamed the AE project. PP created an initial link under one name, and if it's changed within AE, PP can no longer associate it.
I think I have replicated your problem whereby clip (1) that has been exported to AE is replaced with clip (2) after exporting/importing etc,. I cannot attribute it to anything or suggest how you resolve it. I put it down to AE and PP becoming very confused for whatever reason. I was subsequently getting dynamiclinkmanager crashes when starting AE. That was a new one on me.
The cross-linked file issue hasn't happened before and, after a reboot, hasn't happened since.
So, assuming that it didn't happen - try this...
Reverse engineer what you're trying to achieve and see whether that resolves the problem:
- Open a new AE project and save it. Keep it open
- Open a new PP project, import some source material and place a few clips in a new sequence.
- Carry out a "Replace with After Effects Compoosition" on clip 1. The original AE project will take the focus.
- Add an effect in AE, save it and go back into PP
- Do the same with clip 2, and so on until each clip in the sequence has been manuipluated in AE.
At any time do any of your clips become cross-linked - or are you getting the result that you expect?
As an afterthought...
If you want to rework the dynamically linked clip in AE, click on the "Edit original" option in PP. Do not rclick the "Replace with After Effects Composition" again. You should only click on that ONCE - the very first time you initiate the link.
Of course, because it's linked, you can also work on the clip by opening the AE project first, and amending it from there. Reworking a clip doesn't have to be initiated from within PP. I think that may be part of the reason I got the cross-linking issue a moment ago.
North America
Asia Pacific
