Popup reaction is slow
Nov 29, 2010 3:56 PM
Hello,
I am in middle of developing a big application where I am using popups in various places. I have a "SuperPanel" as a container for all my popup windows. This is a customized panel which extends the Flex Panel container.
In one particular scenario I have created a maximize button, clicking on which takes an ADG from the application and displays it on a Popup window. The ADG is a child of a VBox. Now when the user closes the popup the same ADG is collapsed to become a child of the previous container where our maximize button lied.
Everything is working fine except for one thing that the creation of the popup and removal of popup is very slow. It takes more than 4.5 seconds for the popup to be seen on screen and also the same time to be removed from the screen.
This is not the case for other popupwindows where I am displaying a different kind of data.
What can be the reason for such a lag in popup display?
Thanks in advance,
Bhargav
    Nov 29, 2010 5:22 PM   in reply to Bhargav_Flex
    Use the profiler to find out.
    Nov 30, 2010 12:54 AM   in reply to Bhargav_Flex
    Are you simply adding the old ADG? or are you instanciating a new one, adding it to the popup, then filling it with data again?
    Are you also creating the popup, adding the adg, then adding it to the stage, or adding it to the stage, then adding the adg? etc..
    Nov 30, 2010 10:27 AM   in reply to Bhargav_Flex
    Well, before we had a profiler, we would sprinkle in getTimer calls to see
    where the gaps were.
    IMHO, it will save your company money to get you one premium license so you
    can use the profiler instead of using getTimer
    Jan 31, 2013 9:04 AM   in reply to Bhargav_Flex
    A little late, but thanks komal harkut! I was having the same problem, but with
    myPopup.open(FlexGlobals.topLevelApplication as DisplayObjectContainer, true)
    I actually saved 3-4 seconds!
    Although, with retina displays and Flash 11.5 it is still quite slow (everything looks slower actually) so I guess I'll have to run the profiler again and start switching to images instead of vectors. :(
