ggrewe_IPS
OLE error code 0x80040000a: Not able to bind to the source
Dec 2, 2010 12:57 PM
We are using MS Visual FoxPro 9, SP2 in our product.  We use the following code to create an OLE Object and open a PDF file before we attach/embed it into the backend database.
= GETFILE()
gcfile
= CREATEOBJECT('Form') && Create a Form
frmOLEForm
.ADDOBJECT("oleObject", "oleAddObject") && Add OLE object
frmOLEForm
oleAddObject AS OLECONTROL
DEFINE CLASS
     OLECLASS = "" && Server name DOCUMENTFILE = gcfile && This file must exist OLETYPEALLOWED = 0
ENDDEFINE
With Acrobat Reader 9.4.1, this code works fine. With Acrobat Reader X (v10), we recive the following error when issuing the AddObject command;
I have checked the registry and the AcroExch.Document / AcroExch.Document.7 information appears to be registered correctly.  I have tried manually re-registering all the DLL's in the Reader folder, with no luck.  I have been unable to track down what the root cause of this issue might be.  Does anyone have any suggestions?
    Dec 2, 2010 1:50 PM   in reply to ggrewe_IPS
    It would probably work if you disable Protected Mode, since it'll only have a single process in that case, but that hardly fixes the problem for when you want it on.
