I recently purchased a stock template to put together a site rather quickly for a friend. Whenever I open a page and click anywhere in the Code view, regardless of whetehr I have Live Code or Live View enabled, Dreamweaver keeps popping up the following dialog box:
"There are no destinations for Code Navigator to show for this selection."
It just has the OK button which I have to press to then start typing in code view.
This happens every time and obviously slows down my work speed.
Also, if I click anywhere in the Design view, I get a different popup showing the page filename, with a link to the source code and a message to optionally disable the navigator (icon) indicator. But if I click the checkbox it doesn't do anything and the popup comes up every time I click.
So I'm obviously assuming something is not compatible with Dreamweaver the way the template is set up, but I have no idea where to start looking to turn these darn prompts off.
The file uses standard HTML code (no PHP) and the page has a link to an external CSS stylesheet which looks standard to me (I'm not a coder but a designer at heart).
Any ideas would be greatly appreciated!
Some things to check:
1) Your local DW site is properly defined -- Site > Manage Sites?
2) You're working with valid code?
Code Validation Tools
CSS - http://jigsaw.w3.org/css-validator/
HTML - http://validator.w3.org/
Where did you obtain the template?
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
http://alt-web.com/
http://twitter.com/altweb
Don't know if it will make any difference to you, but I suggest taking a look at this thread: http://forums.adobe.com/message/3320666#3320666.
Hi Nancy:
Thanks for the reply. I ran the HTML file through the W3C check and it passed as HTML5.
I purchased the template from here:
http://themeforest.net/item/prosto-business-portfolio-html-css-theme/1 39220
The popups happen when I open the template's sample HTML files without doing anything, so I know it isn't anything I added or edited to the page.
Next I checked the style.css file with the other link you supplied and it DID show 21 errors (this is the original one from the template).
I'm pasting the results here in case anything looks like the culprit to you as I wouldn't know what to do to fix anything (again, I'm a designer more than a coder):
| 20 | .visuallyhidden | Value Error : clip Invalid separator in shape definition. It must be a comma. : rect(1px 1px 1px 1px) rect(1px 1px 1px 1px) |
| 24 | .clearfix | Property zoom doesn't exist : 1 1 |
| 111 | Unknown pseudo-element or pseudo-class :nth-child | |
| 128 | header nav .sf-menu .current_page_item | Property -webkit-border-radius doesn't exist : 3px 3px |
| 128 | header nav .sf-menu .current_page_item | Property -moz-border-radius doesn't exist : 3px 3px |
| 128 | header nav .sf-menu .current_page_item | Property border-radius doesn't exist in CSS level 2.1 but exists in : 3px 3px |
| 129 | header nav .sf-menu li .current_page_item | Property -webkit-border-radius doesn't exist : 0 0 |
| 129 | header nav .sf-menu li .current_page_item | Property -moz-border-radius doesn't exist : 0 0 |
| 129 | header nav .sf-menu li .current_page_item | Property border-radius doesn't exist in CSS level 2.1 but exists in : 0 0 |
| 130 | header nav .sf-menu li:hover | Property -webkit-border-radius doesn't exist : 3px 3px |
| 130 | header nav .sf-menu li:hover | Property -moz-border-radius doesn't exist : 3px 3px |
| 130 | header nav .sf-menu li:hover | Property border-radius doesn't exist in CSS level 2.1 but exists in : 3px 3px |
| 132 | header nav ul.sf-menu ul | Property -webkit-border-radius doesn't exist : 2px 2px |
| 132 | header nav ul.sf-menu ul | Property -moz-border-radius doesn't exist : 2px 2px |
| 132 | header nav ul.sf-menu ul | Property border-radius doesn't exist in CSS level 2.1 but exists in : 2px 2px |
| 135 | header nav ul.sf-menu ul li:hover | Property -webkit-border-radius doesn't exist : 0 0 |
| 135 | header nav ul.sf-menu ul li:hover | Property -moz-border-radius doesn't exist : 0 0 |
| 135 | header nav ul.sf-menu ul li:hover | Property border-radius doesn't exist in CSS level 2.1 but exists in : 0 0 |
| 185 | .cs-title | Property opacity doesn't exist in CSS level 2.1 but exists in : 0.9 0.9 |
| 384 | pre | Property overflow-x doesn't exist in CSS level 2.1 but exists in : auto auto |
| 401 | Unknown pseudo-element or pseudo-class :nth-child |
HTML5 and CSS level 3 support hasn't caught up to all the major browsers and code validators yet. Proprietary rules for Mozilla and WebKit browsers isn't invalid, it just doesn't validate in the W3C's checkers. So don't worry about those CSS errors.
I'm not sure if David's link is helpful to your situation. I'm not a Mac user...
Does your installation of DW include the HTML5 support Pack?
http://labs.adobe.com/downloads/html5pack.html
Nancy O.
http://alt-web.com/
Thanks David and Nancy.
Yes, I followed the instructions on that other message and it fixed it (for now). I do have a Mac and this seemed to have broke after the last Leopard update...but not 100% sure.
Applying the patch did not fix it until after I rebooted.
Keeping my fingers crossed that the problem doesn't resurface like it has for others. What a joy it will be to work again with having to click OK every 5 seconds!
Thanks again.
I encountered the same problem as soon as I installed "moveAddict" daemon (http://kapeli.com/). Apparently this has something to do with assistive devices in OS X. By force quitting moveAddict, Dreamweaver worked as before.
North America
Asia Pacific
