TypeError: Error #2007: Parameter text must be non-null.
Dec 6, 2010 4:57 PM
I'm getting the following error:
at flash.text::TextField/set text()
at Function/<anonymous>()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
This is my code:
myButton.addEventListener(MouseEvent.CLICK, onClickNewFB);
function onClickNewFB(e:MouseEvent):String{
var req:URLRequest=new URLRequest(e.target.name+".txt");
var infoLoader:URLLoader=new URLLoader();
var myInfoLoader:String;
infoLoader.load(req);
myInfoLoader=infoLoader.data;
infoLoader.addEventListener(Event.COMPLETE, loadFeedbackText);
//OSD_feedbackText.text=e.target.name;
return myInfoLoader;
function loadFeedbackText(e:Event):void{
//OSD_feedbackText.text=infoLoader.data;
OSD_feedbackText.text=myInfoLoader;
trace(myInfoLoader);
How do I fix this?  I'm sure I have an incorrect order of operations and I probably shouldn't declare a function within a function but I don't know how else to approach the solution.  Any help is much appreciated.
-markerline
  • kglad
    Jul 21, 2002
    Dec 6, 2010 5:11 PM   in reply to markerline
    that means whatever you're trying to load, isn't being found by flash.  use the trace() function to see what you're trying to load
  • kglad
    Jul 21, 2002
    Dec 7, 2010 12:05 AM   in reply to markerline
    you shouldn't be using an absolute path to your file.  use a relative path so everything works without security issues and without changing when you upload to a server.
  • kglad
    Jul 21, 2002
    Dec 7, 2010 8:32 AM   in reply to markerline
    you're doing everything correctly except when constructing your urlrequest.  your argument is incorrect in the urlrequest constructor is problematic.
    use the trace() function to see what that is and debug.
