peculiar line behavior
Dec 10, 2010 1:14 PM
I'm loading a large CSV file and using it to create and plot a graph.  My client gave me two CSV files for testing.  One has a much greater y axis variance than the other.  When the y axis is drawn for the file with the larger variance it is thickened.  It appears to be about 10 pixels wide as opposed to 2 which the width it's set at.  Also, when I view the file online as aopposed to my desktop, the x axis is thickened in the same manner regardles of which file I use.
Any thoughts would be appreciated.
Best regards,
Chris McLaughlin
  • kglad
    Jul 21, 2002
    Dec 10, 2010 1:39 PM   in reply to Chris McLaughlin
    if you're using scaling, that can be expected to cause the problem you mentioned.
    Dec 10, 2010 1:43 PM   in reply to Chris McLaughlin
    I can't say much beyond it sounds like you are scaling the content.  Lines will get thicker with scaling unless they are hairlines.
    (it's been so long since we collided I've grown lax in checking)
    Dec 10, 2010 2:21 PM   in reply to Chris McLaughlin
    No, that should draw a line as expected, but if yAxis or whatever contains yAxis happens to be scaled in any way,  that will affect how the line appears.
    Dec 11, 2010 5:38 AM   in reply to Chris McLaughlin
    No width or height changes made to yAxis or what holds it?  Where does yAxis live?  How is it brought into existence?
