Divide a circle in 3 seperate segments
Dec 11, 2010 7:30 PM
I need to seperate the circle below into three seperate segments. I know it looks like it already is, i threw it into ps and and saved as a jpg to show you since i dont know how to take a screen shot in illustrator.
basically i created the circle using the shapes button then created a smaller circle and subtracted it from the bigger one. I then created 3 seperate curved lines with a stroke of .5, and after going to path>outline stroke i merged all three curved lines together. I moved the curved lines to the top, selected them, and then selected the circle below the curved lines and hit subtract to divide the circle into 3 sections. Only problem is they are not 3 seperate segments. When i use the selection tool to click on the circle it outlines the entire circle along with the strokes i created.
I need 3 seperate segments that are each able to be manipuated on their own. How do I do this?
I tried making the strokes and the circle a compound shape from the appearance panel, and then using the direct selection tool to select the anchor points of the curved lines and then press ctrl+x to cut them out, but that didnt work.cirle open.jpg
    Dec 11, 2010 8:57 PM   in reply to mhossey
    You might just need to select everything and go to:
    Object→ Ungroup
    Or right click and choose it there.
    I would use pathfinders 'Divide' for what you are trying to do. But I'm on PC with CS5. Maybe Subtract is exactly what you need.
    I don't seem to need to use the Path→Outline Stroke step.
    Dec 11, 2010 9:08 PM   in reply to mhossey
    I've played around with it, and seem to get random results. Sometimes it does split them into different shapes, othertimes it does not. You might try remaking it. I'm not sure if the shape of the curve has anything to do with it, or if the curved paths need to end outside of the shape.
    Dec 11, 2010 9:11 PM   in reply to mhossey
    Does subtract work with the expand button? Or is it an auto-finalized action? Your shape might still be in 'live mode'.
    Dec 11, 2010 11:14 PM   in reply to mhossey
    Look at your shape in the Layers Panel. I think that you'll find that it's a compound shape. Select it and go to Object>Compound Shape>Release. Deselect, then click on one segment of the circle, and you should find that just that part is selected.
    Peter
    Dec 11, 2010 11:19 PM   in reply to mhossey
    In CS5 we can select the group and select the "Live Paint Bucket" which would surely pick out those three shapes.
    Dec 11, 2010 11:34 PM   in reply to Mellifluous-Irony
    That's fine for coloring them, but I assumed that "segments that are each able to be manipulated on their own"  meant moving, resizing or reshaping.
    Peter
    Dec 12, 2010 12:05 AM   in reply to tromboniator
    I wasn't addressing your statement
    I posted and both of your replies appeared infront heh.
    Well done on finding the solution.
    Dec 12, 2010 1:18 AM   in reply to Mellifluous-Irony
    Oh, yeah: time warp! Gotcha, thanks.
