Voting poll using PHP & MySQL >>TypeError: Error #2007: Parameter text must be non-null.
Dec 12, 2010 11:17 PM
I am getting this back:
at flash.text::TextField/set text()
at AS3_Flash_Poll_PHP_MySQL_fla::WholePoll_1/completeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
PHP code:
<?php
// ---------------------------------------- Section 1 -----------------------------------------------
// IMPORTANT!!!! Connect to MySQL database here(put your connection data here)
mysql_connect("ginaty05.fatcowmysql.com","fall2010","@regina") or die (mysql_error());
mysql_select_db("poll_2010") or die (mysql_error());
// When Flash requests the totals initially we run this code
if ($_POST['myRequest'] == "load_numbers") {
// Query the totals from the database
$sql1 = mysql_query("SELECT id FROM votingPoll WHERE choice='1'");
$choice1Count = mysql_num_rows($sql1);
$sql2 = mysql_query("SELECT id FROM votingPoll WHERE choice='2'");
$choice2Count = mysql_num_rows($sql2);
$sql3 = mysql_query("SELECT id FROM votingPoll WHERE choice='3'");
$choice3Count = mysql_num_rows($sql3);
echo "choice1Count=$choice1Count";
echo "&choice2Count=$choice2Count";
echo "&choice3Count=$choice3Count";
// ---------------------------------------- Section 2 -----------------------------------------------
// IF POSTING A USER'S CHOICE
if ($_POST['myRequest'] == "store_choice") {
//Obtain user IP address
$ip = $_SERVER['REMOTE_ADDR'];
// Create local variable from the Flash ActionScript posted variable
$userChoice = $_POST['userChoice'];
$sql = mysql_query("SELECT id FROM votingPoll WHERE ipaddress='$ip'");
$rowCount = mysql_num_rows($sql);
if ($rowCount == 1) {
$my_msg = "You have already voted in this poll.";
print "return_msg=$my_msg";
} else {
$sql_insert = mysql_query("INSERT INTO votingPoll (choice, ipaddress) VALUES('$userChoice','$ip')") or die (mysql_error());
$sql1 = mysql_query("SELECT * FROM votingPoll WHERE choice='1'");
$sql2 = mysql_query("SELECT * FROM votingPoll WHERE choice='2'");
$sql3 = mysql_query("SELECT * FROM votingPoll WHERE choice='3'");
$my_msg = "Thanks for voting!";
echo "return_msg=$my_msg";
echo "&choice1Count=$choice1Count";
AS3 code:
stop(); // Stop the timeline since it does not need to travel for this to run
// Assign a variable name for our URLVariables object
var variables1:URLVariables = new URLVariables();
// Build the varSend variable
var varSend1:URLRequest = new URLRequest("parse_my_poll.php");
varSend1.method = URLRequestMethod.POST;
varSend1.data = variables1;
// Build the varLoader variable
var varLoader1:URLLoader = new URLLoader;
varLoader1.dataFormat = URLLoaderDataFormat.VARIABLES;
varLoader1.addEventListener(Event.COMPLETE, completeHandler1);
// Set variable to send to PHP here for the varloader below
variables1.myRequest = "load_numbers";
// Send data to php file now, and wait for response using the COMPLETE event
varLoader1.load(varSend1);
function completeHandler1(event:Event):void{
count1_txt.text = "" + event.target.data.choice1Count;
count2_txt.text = "" + event.target.data.choice2Count;
count3_txt.text = "" + event.target.data.choice3Count;
// hide the little processing movieclip
processing_mc.visible = false;
// Initialize the choiceNum variable that we will use below
var choiceNum:Number = 0;
// Set text formatting colors for errors and success messages
var errorsFormat:TextFormat = new TextFormat();
errorsFormat.color = 0xFF0000; // bright red
var successFormat:TextFormat = new TextFormat();
successFormat.color = 0x00FF00; // bright green
// Button Click Functions
function btn1Click(event:MouseEvent):void{
choiceNum = 1;
choice_txt.text = choice1_txt.text;
function btn2Click(event:MouseEvent):void{
choiceNum = 2;
choice_txt.text = choice2_txt.text;
function btn3Click(event:MouseEvent):void{
choiceNum = 3;
choice_txt.text = choice3_txt.text;
// Button Click Listeners
btn1.addEventListener(MouseEvent.CLICK, btn1Click);
btn2.addEventListener(MouseEvent.CLICK, btn2Click);
btn3.addEventListener(MouseEvent.CLICK, btn3Click);
var variables:URLVariables = new URLVariables();
var varSend:URLRequest = new URLRequest("parse_my_poll.php");
varSend.method = URLRequestMethod.POST;
varSend.data = variables;
var varLoader:URLLoader = new URLLoader;
varLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
varLoader.addEventListener(Event.COMPLETE, completeHandler);
// Handler for PHP script completion and return
function completeHandler(event:Event):void{
// remove processing movieclip
// Clear the form fields
choice_txt.text = "";
choiceNum = 0;
// Load the response from the PHP file
status_txt.text = event.target.data.return_msg;
status_txt.setTextFormat(errorsFormat);
if (event.target.data.return_msg == "Thanks for voting!") {
// Reload new values into the count texts only if we get a proper response and new values
status_txt.setTextFormat(successFormat);
// Add an event listener for the submit button and what function to run
vote_btn.addEventListener(MouseEvent.CLICK, ValidateAndSend);
// Validate form fields and send the variables when submit button is clicked
function ValidateAndSend(event:MouseEvent):void {
//validate form fields
if(!choice_txt.length) {
// if they forgot to choose before pressing the vote button
status_txt.text = "Please choose before you press vote.";
} else {
status_txt.text = "Sending...";
processing_mc.visible = true;
// Ready the variables for sending
variables.userChoice = choiceNum;
variables.myRequest = "store_choice";
// Send the data to the php file
varLoader.load(varSend);
} // close else after form validation
} // Close ValidateAndSend function ////////////////////////
