backroom boy
Working with ContentSpace in Workbench
Dec 16, 2010 2:08 AM
The thing, i want to do ,is to obtain set of xml-files (or/and their
direct paths and names)  from some ContentsSpace folder.What am I doing
: I'm creating GetSpaceContents opeation and receive  list<CRCResult>
variable. The question is :1. how should I obtain (what functions ,
using xpath or smth. else) the file directly and its attributes (such as
path, name)?
2. Can we access to each of the CRCResult variable in the list (
mylist[1], for example)?It didn't work out in my case.If we can't , why?
How should we produce that?
Thanks in advance.
    Dec 16, 2010 3:14 AM   in reply to backroom boy
    Inline.
    1. how should I obtain (what functions, using xpath or smth. else) the file directly and its attributes (such as path, name)?
    From a variable of type CRCResult one can use xpath to get the file directly, its attributes etc.
    Access File Contents:-
    /process_data/CRCResultVar/object/@document
    Access File Attributes:-
    /process_data/CRCResultVar/object/attributeMap
    2. Can we access to each of the CRCResult variable in the list (mylist[1], for example)?It didn't work out in my case.If we can't , why? How should we produce that?
    Yes we can do that using following xpath notation:-
    /process_data/myList[1]
    For more details please see the following snapshots of the sample process:-
    1. getSpaceContents(): Method gets the contents from space and stores them as a List of CRCResult object. (e.g. outputList<CRCResult>)
    2. execute(): Operation performs following steps:-
    •                 2.1 Fetch first item from outputList and assign it to a CRCResult variable (i.e. crcObj1 in our case) /process_data/crcObj1 = /process_data/outputList[1]
    •                 2.2. Fetch file contents from the CRCResult Object and store it to a Adobe Document Object(fileContent in our case) /process_data/@fileContent= /process_data/crcObj1/object/@document
    •                 2.3 Fetch file attributes from the CRCResult Object and store it to a string Map Object(fileAttrMap in our case) /process_data/fileAttrMap = /process_data/crcObj1/object/attributeMap
    Hope that answers your question well.
