Adobe Media Encoder hanging
Dec 17, 2010 12:01 PM
Premiere Pro CS4
File > Export > Youtube SD > 640x480
Media on C drive > encoding to C drive
After 3 mins, adobe media encoder hangs, elapsed queue time does not move, elapsed time does not move, estimated remaining does not move.
I only have 2 titles in video, no video transitions, and an mp3 audio file i added in.
what should i try?
    Dec 17, 2010 1:59 PM   in reply to remotepcaccess
    Same exact thing happening to me. CS4, encoding to VBR 2-pass F4V (H.264) with AAC audio. PProHeadless.exe seems to still be pulling from the CPU and using RAM, but Adobe Media Encoder.exe process showing RAM usage but 0% CPU. It doesn't say "not responding" however. Estimated Remaining timer has not moved in an hour. How do I know if it's frozen?
    Dec 17, 2010 8:53 PM   in reply to remotepcaccess
    what should i try?
    A different project with different media.  Does it still hang, or only on this project?
    Dec 17, 2010 9:46 PM   in reply to Jim Simon
    Actually, this may help. Since it didn't say "Not responding", I just went to a different computer and left it alone. Eventually, it started back up again and finished, although it did end up taking about 6 hours to encode - which is a lot for a dual, dual core computer hyperthreaded to 8 cores! I suppose it just needed more time that it estimated (by about 300%).
    Dec 20, 2010 11:19 AM   in reply to remotepcaccess
    Try converting the .mp3 to a .wav and using that instead.
    Dec 20, 2010 12:30 PM   in reply to remotepcaccess
    I also support the conversion of the MP3 to PCM/WAV 48KHz 16-bit, and Importing that.
    As for "covering" you longer Video, well that will depend.
    Can you just drag multiple Instances of the Audio, until you have a match for the Video? It might be easier to do this cleanly and smoothly in the audio-editing program used to convert.
    As that is a big "stretch" (no pun intended), I doubt that the pitch of that Audio can be maintained with something like the TimeStretch Tool.
    Dec 20, 2010 4:52 PM   in reply to remotepcaccess
    OK, what are the specs of the video files you are using?
    Dec 21, 2010 8:49 AM   in reply to remotepcaccess
    Good.
    Did these clips come from a camera?  If so, which make and model?
    Dec 21, 2010 12:14 PM   in reply to remotepcaccess
    That causes a little concern.  Can you find out?
