Preset for Flip HD slide Camera
Dec 18, 2010 12:05 AM
There are several FLIP settings.  Which one should I use for the best video quality?  Premiere Elements 9 select the "AVCHD Lite 720p" option, when I upload FLIP videos.  Is this the optimal setting?  Or should I select of the settings under FLIP?
    Dec 18, 2010 8:30 AM   in reply to onlinetravels
    You very much should use the Flip HD preset.
    Flip camcorder use a proprietary codec (compression system) and you must use the correct preset to get any decent results.
    Unfortunately, Flip doesn't publish specs on its site, so you may need to experiment a bit to find the right preset.
    If you've selected the right preset, your video will load onto the timeline with no red lines above it until you add a transition or effect to the clip.
    When you find it, please report back here so we'll know what to recommend next time.
    Dec 19, 2010 6:09 PM   in reply to onlinetravels
    The only way to do it is with a program called ClipMate, available online.
