samwittlindvm@aol.com
filename after scanning has the correct month but the wrong day
Dec 20, 2010 11:45 PM
is there a way to change the default settings and or correct the date/name of a scanned document. The file name of the scanned document reflects the scan profile plus the year...month..day...hour(in military)...minute...second. The day is incorrect. What can be done to correct this. The computer time is correct.
I have tried two separate scanners with the same results. thanks
    Dec 21, 2010 4:31 AM   in reply to samwittlindvm@aol.com
    Can you explain the exact steps you are using to create the PDF?
    Mar 1, 2011 7:57 PM   in reply to samwittlindvm@aol.com
    This is NOT RESOLVED and is a BUG (is there a better place to post a bug?). I will explain the issue and how to duplicate it.
    Adobe Acrobat X Pro 10.0.1
    When scanning to PDF via an action the file name is incorrectly generated one day ahead of the current.
    Example: A file scanned in today (03/01/11) shows the following filename:
    Scans_201132201258
    The file name structure breaks down like this:
    (Scans=name of action used to generate scan)_(2011=year)(3=month)(2=INCORRECT DATE / current date +1)(201258=20hrs 12min 58sec)
    Here the EXACT steps I used to create this issue:
    File > Create > PDF from Scanner > Configure Presets
    Options > Select my scanner
    Presets: Autodetect Color Mode
    Optimize Scanned PDF checked (probably not important to issue replication)
    Make Searchable checked (probably not important to issue replication)
    Save
    File > Action Wizard > Create New Action
    Starts with: A Scanned Document > Autodetect Color Mode
    No Steps
    Save to: A folder on my computer
    Options box to the right of Save To selection (set to default settings)
    Keep original file names checked
    Save File(s) as Adobe PDFs checked
    Overwrite existing files checked
    Saved action as 'Scans'
    File > Action Wizard > 'Scans'
    File scans and opens with filename incorrect
    Mar 1, 2011 11:05 PM   in reply to shizah304
    Yes, this is a bug. The engineering team is working on this and we are targetting for a fix in the next update.
    Mar 2, 2011 6:05 AM   in reply to AbhigyanModi
    Great news! Thank you for posting a response so quickly.
