Converting PDF files with tables back to Microsoft Word without lossing the format
Dec 21, 2010 12:38 PM
I am trying to convert a large amount of PDF files that has tables on them (some are filliable Forms). I need to convert the files to Microsoft Word 10. I have tried to convert the files by using the export option but it would lose the format and the tables would go crazy. Is there a software that I could buy or a process that I could use to get the files to export the files without losing the format. Hopeful I have explained this issue clear enough in order to get help.
    Dec 21, 2010 12:55 PM   in reply to malloy_david
    That suggests that the PDF was not created with PDF Maker that retains the format information. As a result, there is not much you can do with Acrobat if it is not converting properly. You can try to save as HTML or RTF and import those into WORD. Sometimes those conversions will do better, but not real sure.
    You can also use a copy and paste from the PDF with the alt key held down to force the column mode of copy. Unfortunately, with Acrobat there is not much more you can do. There are some 3rd party products that focus on the conversion to WORD and I understand do a much better job for the type of untagged document you likely have. Check with PDF Zone or Planet PDF for the 3rd party solutions. Be aware, they are not cheap either.
    Dec 22, 2010 6:47 AM   in reply to malloy_david
    No, that is why I referred you to the other two sites. Folks have posted the product names in the distant past, but those posts are likely long gone.
