Why? SOAP Response cannot be decoded. Raw response: null
Dec 23, 2010 10:02 AM
I'm developing an Application in Flex 4 that contacts with webservices.
If I run my application with firefox or Chrome when it should catch one exception from the webservice, it doesn't show my exception message and show that error: SOAP Response cannot be decoded. Raw response: null
If I run my application with ie8 or with flash player (out of browser), it catch my exception and show my exception message... And this is OK.
Any ideas for my problem?
Best regards,
Miguel
    Dec 27, 2010 7:26 AM   in reply to migueldmag
    can you post some of your code. what kind of service are you calling are you calling a .net webservice
    ? do you have a fault? set up on your service of a are you catching the error on your service and returning it as part of the xml?
    if you answer some of those questions ill be able to help you further.
    ty to put a breakpoint and study the result of the webserice you might be getting a 500 error from your service.
    respond back
    miguel
    Dec 27, 2010 10:35 AM   in reply to migueldmag
    ok by the sound of what your describing it sounds like you are running into browser compatabilitys iss
    ues. here is where i would suggest you start. When you are debuging put a brake point on the
    fault function that gets kicked off when the decoded error is happening. Once you do that look at the result event in the variables tell me what you see. I could almost guarantee that you would be getting a 500 error from browser.
    Also another thing you should check is that you have the xml file on the root of your service that allows to go across domains? do you have that already in place?
    respond back with your findings. I've been threw many of these issues. however i will confess im not a wizard guy i usually code it all out manually.
    Miguel
    Dec 28, 2010 2:03 AM   in reply to migueldmag
    Hi migueldmag,
    Can you post the url of your WebService which you are using..(wsdl url)..??
    Bhasker
    Dec 28, 2010 3:57 AM   in reply to migueldmag
    miguel
    this is what i was looking for
    ORA-00942:
    This error suggest that the table or view does not exist in oracle, been there many times. now we can work backwards. your webservice seems to be unstable. so now you have two options. You can try to debug your webservice and figuere out what's wrong there, or you can post the url here so that we can try to help you debug. I can tell you from my experience with the .net webservice im pretty sure your trying to contact an oracle database and the function has a problem in the code.
    are you using odp.net? are you using oledb? are you using microsoft oracle data provider?
    Let us know which steps you want to take more then happy to help  you with this one.
    Miguel
    Dec 28, 2010 5:11 AM   in reply to migueldmag
    ok well then may i suggest something else then. Perhaps what you can do is put an excepetion handler on your
    .net webservice. once it hit exception then it will return the exception withing  a give XML tag in  other words your fault will never get triggered in flex.  Perhaps and im very sqeptical saying this you have hit some compatability issues with the flash player and the browser you have problems with. However i think that if you get the catch the exception in the .net side and return it as part of an xml then you should be ok.
    miguel
    Message was edited by: miguel8312
    Dec 28, 2010 7:51 AM   in reply to migueldmag
    miguel
    Im taking a guess at best. Without seeing code or being able to call service myself there is not much we can do to help. I do think that if instead of letting your .net webservice failed and instead you  catch the exception and pass it as xml you would problably not going to recieved errors from other browsers.
    Miguel
    Dec 28, 2010 8:48 PM   in reply to migueldmag
    Hi migueldmag,
    Can you host your WebService on public server and share the link..?? I am sure the problem is with the WebService only which you are using..
    Bhasker
    Jan 7, 2011 2:33 PM   in reply to migueldmag
    I've just ran into this error today. On macos and IE i will receive a soapfault which i can display the faultstring from the server. but on windows in firefox or chrome i get and RPC fault instead which doesn't allow me to show a nice error message from the server.
    [RPC Fault faultString="SOAP Response cannot be decoded. Raw response: " faultCode="DecodingError" faultDetail="null"]
    I'm using a build of HERO (4.5.0.17855). version 4.5.0.18623 has a bunch of ther soap errors that i've ran into.
    I'll try switching back to 4.1 later to see if that fixes it later on.
    -Nate
    Jan 12, 2011 10:34 AM   in reply to migueldmag
    I'm not sure if this is a browser realted issue or plugin. i would expect to see the same results. since these browsers use the same plugin.
    it was compiled using flex 4.1 target player version 10.
    Doesn't work means it isn't able to decode the soapfault.
    Firefox (3.6.13) - Windows7
         FP 10,0,45,2 - Doesn't Work
         FP 10,1,102,64 - Doesn't Work
         FP 10,2,151,49 - Doesn't Work
    Safari (5.0.3) - Windows7
         FP 10,0,45,2 - Works
         FP 10,1,102,64 - Works
         FP 10,2,151,49 - Works
    Chrome (8.0.552.224) - Windows 7
         FP 10,1,103,20 - Doesn't Work
    IE - Windows 7
         Works (dont have more details)
    Safari - OSX 10.6.6
         Doesn't Work
    Chrome - OSX 10.6.6
         Doesn't Work
    Firefox - OSX 10.6.6
         Works
    Jan 12, 2011 9:01 AM   in reply to migueldmag
    I was able to reproduce the same error in OSX using chrome.
    Chrome - OSX 40.6.6
         FP - 10,1,103,19 -  Doesn't Work
         FP - 10,1,102,64 - Doesn't Work
    Jan 12, 2011 9:54 AM   in reply to migueldmag
    When i debug the exception. The very first item that is in the stack is DirectHTTPMessageResponder/errorHandler.
    One of the lines in the method is as fallows.
    msg.body = URLLoader(event.target).data;
    in the browsers that work the msg.body will contain the full soap envelope with the exception details.
    in browsers that don't work msg.body is an empty string.
    -nate
    Jan 12, 2011 12:12 PM   in reply to migueldmag
    == SOLVED ==
    Flash relies on the browser network stack to get results. etc..
    Some browsers will stop and not send flash the body content if it receives a 500 Status code. The best way to fix the error would be to make the .net code not send a 500 status when you are sending a soapfault.
    protected void Application_EndRequest(object sender, EventArgs e)
         if (Context.Response.StatusCode == 500 || Context.Response.StatusCode == 300)
               Context.Response.StatusCode = 200;
    Jan 24, 2011 2:50 PM   in reply to migueldmag
    Problem Solved.
    We were having this problem intermittently with a Flex 4.1 App running off of a ColdFusion 9 Server. It turned out that the Error 500 was misleading. By removing <cfdump> tags, the error disappeared. My recommendation: always remove the <cfdump> tags from the production code.
    Jun 27, 2011 12:00 AM   in reply to seanscottusa
    Hey,
    I am also using ColdFusion9 webservice with Flash Builder 4 and 4.5 sdk and getting the following error(which resemble a single one) in different conditions and these is no CFDump tag, in the webservice which I am using, can you please help:
    When I run the application/or say publish it in AIR, within Flash Builder 4 and try searching, I get this error after 2-3 searches:
    Error#1085: The element type "P" must be terminated by the matching end-tag "</P>".
    Null
    And If I simply run the AIR application, outside the Flash Builder, Then I get the following error:
    Error #1085
    Null
    And If I publish my application as normal SWF file into HTML and not AIR, then the error says:
    SOAP response cannot be decoded. Raw response:
    null
    Chit1
    Dec 12, 2012 1:57 AM   in reply to Nate Burr
    I am new for flex development. I have just started development in flex 4.6.
    I am also facing the same problem. Even after ading the C# code, Issue is still persist.
    So I decided to do testing in different maner. I create new method called TEST(string xmlValue) having return type String. In this method I simply return xmlValue as String.
    [WebMethod(EnableSession = true)]
        public string TEST(string xmlString)
            XmlDocument xdoc = new XmlDocument();
            xdoc.loadXml(xmlString);
           return xdoc.OuterXML;
    I replace the method name in flex application and test. I still got the error. I guess there is some flex issue in this.
    But I don't understand before calling this method there are 3-4 web service call which works absolutly fine and when it comes to the 5th call it returns me fault.
    FIENDS PLEASE HELP ME. I NEED TO DELIVER IT AS SOON AS POSSIBLE. I AM ALREADY CROSS DEAD LINE.
    PLEASE HELP ME.
