new elements 9 installed in new imac, the editor workspace is 'busy' so can't use it.  what to do?
Jan 3, 2011 5:53 AM
New elements 9 installed on new iMac, the
editor workspace is "busy" so can't use it.
What do I do?
    Jan 3, 2011 6:35 AM   in reply to melvin1873
    Do you have syncing set up? Has it ever worked without a problem?
    Jan 3, 2011 6:45 AM   in reply to melvin1873
    First, can you give me the specs on your hard drive: overall capacity and how much free space you have?
    Did you install Premiere Elements as well?
    Jan 3, 2011 12:06 PM   in reply to melvin1873
    4GB would be your ram, not your hard drive space (which will be something like 500GB overall).
    Jan 3, 2011 3:28 PM   in reply to melvin1873
    Okay, and when you open a finder window, what does it show as "available" down at the bottom? And you didn't do anything special with where you installed PSE, did you? (like on a separate partition or anything?)
    Jan 3, 2011 7:18 PM   in reply to melvin1873
    Great, glad you were able to shake whatever it was loose.
    Jan 5, 2011 12:06 AM   in reply to melvin1873
    Hi Melvin,
    The Editor workspace is busy message usually appears when it's in Create mode and you try to edit and image in Organizer using the Edit with Photoshop Elements option in the right click menu. In future, if you come across this message, just switch back to the Full Edit mode. You don't need to reboot
    Regards,
    Chhaya
