retiredr
Black screen
Jan 4, 2011 5:42 AM
Mac user OS 10.6.5, Safari 5.0.3.  Several weeks ago tried to download a form from the Gov an was told I need to have Adobe Reader Ver 9 or higher.  Download Adobe Ver 10.  Went back to the Gov site and tried down load the form again.  Screen was black.  Address bar showed that I was on the page to be downloaded.  Contacted Gov help, said not their problem.  Sent an e-mail to Adobe, no response.  Have tried to download Ver 9.4, same problem black screen.  Can't use the orginally installed Ver 7.  Nothing but black screens.  Tried using the help from Adobe, no help.  What do I need to do to correct this problem?  Is it something that I did wrong?  Heelllpp!
Jim
    Jan 4, 2011 7:28 AM   in reply to retiredr
    Try to check this option: Edit > Preferences > Page Display > Show Large Images
    Jan 4, 2011 9:38 AM   in reply to retiredr
    Could you share the link to this file?
    Jan 4, 2011 9:50 AM   in reply to retiredr
    The file itself is fine. Try saving it locally and then double-clicking it
    instead of opening it in your browser.
    Jan 4, 2011 10:14 AM   in reply to retiredr
    I suggested it as a way of locating the problem through deduction, not as
    what you should do from now on.
    By the way, mixing versions like that is not recommended. You should try
    uninstalling everything and then installing just one version.
    Jan 5, 2011 4:49 AM   in reply to try67-Ack7pB
    I have exactly the same problem.  I've reinstalled Reader X several times and still get black screen whenever I try to open a pdf.  This wasn't a problem before I upgraded to X.  Please help.
    Jan 5, 2011 4:52 AM   in reply to callie4512
    One other thing.  When I look at the "more info" in the application, there's a box that says "open in 32 bit mode", which is checked.  I have Snow Leopard.  Thought this might be the problem, but when I unchecked it, still got black screen.
    Jan 6, 2011 3:57 PM   in reply to retiredr
    Amazingly, I found that the problem goes away when I use the Chrome browser!!  Have no idea why.  It's the only browser I can use to get a pdf.  Try that, and see if it  works for you.
    Jan 11, 2011 11:32 PM   in reply to retiredr
    Hi Jim,
    I am using MAC OS 10.6.6 (latest update from MAC) with Safari 5.0.3
    I am able to download and view 1010EZ form in my safari (from the link you provided). Also I can see links to start filling application online in pdf forms as well as I am able to download the form to fill it offline. Did not see any Black Screen.
    Can you check that you are able to open other pdfs in safari. Browse for some PDF on net or open any pdf present in your system in Safari. Also is Reader X your default application to open pdfs in Safari? You can check that by opening a plist file in any plist editor. Open file: /Library/Preferences/com.adobe.acrobat.pdfviewer.plist and check key WebBrowserUsePath. This should point to Adobe Reader application. Also check version of /Library/Internet Plug-Ins/AdobePDFViewer.plugin. This should be 10.0.
    Karan
