Please refer to this thread--
http://forums.adobe.com/thread/755480?tstart=0
--there are commonalities, but it's somewhat different so I'm starting a new thread.
Client is Win 7/x64, server is SBS2008 SP2. The remote share is a DFS share. I'm able to open files with ARX from \\domain.local\DFSRoot\DFSFolderName, but not from a Symbolic Link to the DFSFolderName folder. The path the SymLink displays is C:\Users\Public\Desktop\DFSFolderName. When I try, I get this message:
Adobe Reader
There was an error opening this document. Access denied.
[OK]
Turning off Enable Enhanced Security in Preferences/Security (Enhanced) makes no difference.
Did not have this problem with AR 9.4.
If I map a drive to the DFS share, I seem to be able to open files from the drive map or the UNC, regardless of the setting of Enable Enhanced Security.
I have what appears to be the same issue, except I encounter the issue when I try to access a file on my local drive in a folder that is a Symbolic Directory Link. Without making any changes to ARX or anything else, I can get ARX to open the file simply by accessing the file using its actual folder path. Maybe this will help...
C:\Folder1\MyPDF.pdf
C:\SymLink\MyPDF.pdf
NOTE - Unchecking "Enable Protected Mode at startup" does prevent this problem! (Edit -> Preferences, bottom of "General" section). However, if you want the added security offered by protected mode, then you will need to avoid the use of symbolic links until Adobe addresses this issue. I am using version 10.1.4, the latest released version as of 10-06-2012 (October 6, 2012).
I have recreated this in multiple ways, with many different types of PDF documents, which were created by three different applications. I have already spent too much time researching this, and found my workaround for this until it is addressed by Adobe. In every case, it breaks ONLY when I try to access the file using a symbolic link in the path name. Note that Windows 7/8 uses symbolic directory links in a few instances, and if someone uses those folders to store PDF's, they could have problems.
NOTE - Anyone can create a symbolic link in Windows 7/8 by using the "mklink.exe" command at a command prompt. It is included with Windows. I have not tested whether soft or hard links to the file itself will cause the problem, but I could upon request if anyone thinks it wouldn't be time wasted. The time I can spend on a PC at one time is limited since a car accident, but I will do it if it could help other avoid the problem that I banged my head against a wall trying to figure out.
I hope this help others facing this issue, and I hope Adobe addresses this issue in an update very soon.
-TSForrest
Good luck and happy hunting!
North America
Asia Pacific
