Audition for Mac Won't Record or Play
Jan 5, 2011 5:26 PM
Audition for Mac launches just fine.  But when I hit record nothing happens.  I can't even open a .wav file to play it.  I also noticed that I can no longer view my meter input signal.  I am going to try a reinstall and see if that solves the problem.  Update: Uninstalling with AppCleaner and reinstalling Adobe Audition for Mac did not change anything.  I still can't record or play a file.  Any other suggestions?
    Jan 6, 2011 9:33 AM   in reply to treswrld
    In Finder, click your username, then Library > Preferences > Adobe > Audition   and rename the 4.0 folder (or move it to the trash.)  Then launch Audition and it should rebuild the preferences files to their defaults.  That should probably resolve the issue.  If not, we can keep troubleshooting and look at your audio driver settings.
    Did you recently update OS X by any chance?
    Jan 12, 2011 7:45 PM   in reply to _durin_
    After having a similar problem and going through the steps you suggested (re-naming the 4.0 folder), everything has defaulted and I now can't find the unique EQ filter and reverb settings that I had created before. Can you tell me how I can re-load those again? Thank you.
    Jan 17, 2011 10:22 AM   in reply to Sleepykat18
    These should be in "EffectPresets.xml" and you can copy that back to the current 4.0 preferences folder.
