Copy and Paste Layers from one .psd file to another?????
Jan 9, 2011 7:09 AM
I'm having a few difficulties copying and pasting layers from one psd to another, this will save me a lot of time.
The problem is that I cannot select a layer and then copy it to the clipboard.
Any help is appreciated.
You guys are great.
Jon
  • Noel Carboni
    Dec 23, 2006
    Jan 9, 2011 7:28 AM   in reply to gatsu118
    Have you done a Select - All after making the layer current?  Edit - Copy requires that.
    However, it might be better for you to just drag the layer(s) from document to document, though...  You will carry all the data beyond the edges of the visible canvas that way.
    If you're using tabbed view, tile the windows on the screen, make the document you want to copy from current, grab the layer(s) from the Layers panel and drag them to the document you want to copy to.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 9, 2011 7:58 AM   in reply to gatsu118
    Hold the Shift key down when dropping the layer after dragging it.  Then it will be placed in the same location it was in the source document.
    -Noel
    Jan 9, 2011 8:08 AM   in reply to Noel Carboni
    Another easy way to do what you want to do rather then copy paste.
    With both images open. make a new layer on the target image. then choose Image>apply image and choose the opened image you want to make a copy of . it will place that image center on a new layer no fuss and no tiled windowed images.
    the trick is they have to  be the same size images.
    Jan 9, 2011 9:46 AM   in reply to gatsu118
    Yet another way is to select the layer or layers and choose duplicate layer(s)
    and then choose the name of your destination document in the dialog.
    If the documents are the same size, then the layers will be in the same position
    in the destination document.
    MTSTUNER
  • Noel Carboni
    Dec 23, 2006
    Jan 9, 2011 10:17 AM   in reply to MTSTUNER
    function(){return A.apply(null,[this].concat($A(arguments)))}
    Nice!  Up to now I have always ignored that Destination Document field.  Hidden in plain sight from me it was.
    Thanks for that tip, MTSTUNER.
    -Noel
    Apr 28, 2011 6:08 AM   in reply to Noel Carboni
    Not really the right place but can't find an answer to this anywhere - help?
    Is there an equivalent of the duplicate layer to another destination document for Illustrator?
    Use this command all the time in photoshop and could do with doing the same thing on about 20 or so illustrator eps
    Apr 28, 2011 10:13 AM   in reply to Michael ONeil
    In Illustrator just copy and paste. Make sure Paste Remembers Layers is checked in the Layers panel menu. To select all objects in a layer click at the far right on the layer, right side of the little circle. Shift + Ctrl + V pastes in the same place.
