Hi Mark,
thanks for your reply, yes I do have the file already made with PSE, now I
wish to change the name on that business card and phone number, as well I
need to change the size of that business card to a post card, also need to
learn how to create more text, thanks
Best
Regards
Caroline
Hallak
www.CarolineHallak.com
International Fashion Designer,
One-of-a-Kind Design,
Imported European Fabrics,
Custom-Made in One-Fitting... from size 2-24
Home Collection
Style Gala Couture Inc.
www.StyleGalaCouture.com
Appointment Strongly Recommended (323)836-1865
9437 S. Little Santa Monica Blvd. suite 200, Beverly Hills CA 90210
Since the card is a PSE file, are the various pieces of text separate text layers? If so you can easily go back into the layers with the Text tool and change the wording, size, font, etc. It would help if you upload to this forum (click the camera icon) a screen shot showing your PSE desktop with the open file and open Layers Palette.
ok, I have the trial version, so maybe its missing some function, but it doens'st make sense , how I can try it,
text tool it doens't exist in the layer, theirs a lot of funstions are not white, thta means we can't click on them??
what camera icon?
text layer, I can' find it, also activate the layers palette it deons't exist too...
pls give me the step where to click first, and than, thanks
Caroline,
I made this simple example which should help explain things. I have PSE2 so things will look a bit different than in your version but functionally they should be the same.
The Text tool is the 2nd column in the 4th row of the toolbar along the left side. It is denoted by the "T" icon.
The Layers Palette is opened via the menu bar: Window > Layers. You can also open it from the Palette Well which is located in the upper right of the menu bar. The Palette Well is customized by the user to access certain frequently-used tools (I have just the 4 items Filters, Effects, Layer Styles, and Layers). Click on the Layers tab to temporarily open the Layers Palette. You can also drag the tab to the desktop so that the Palette stays open, which you probably want to do and which I did in the above screenshot.
Now for the example:
I created a blank file, clicked the "T" icon to activate the Text tool, and added the text "TEXT LAYER". This created the new layer named "TEXT LAYER" (you can rename the layer if you want).
To later change the text, activate the Text tool, click in the text where you want to made changes, and type away. You can also delete text with the Backspace or Delete key, just as in a word processor. To highlight a section of text for editing just click and drag as in this example:
When I mentioned the camera icon I was referring to the icons above the message box in the PSE forum. The camera icon is in the lower right corner of this screenshot. When you click the camera it asks you for the path to the picture you want to insert into the message at the cursor point.
Mark thanks for all the details, but definatly I do have a different version
or something, because I really don't have what you are describing, and I
think I try everything I can to see how I can change the text and I really
can't..
so pls if someone can call me (323) 836-1865 and show me what to do with the
version that I have, thanks
Everything I described is basic stuff to all PSE versions, and what you are trying to do (change text, resize) is also basic stuff.
Again, it would greatly help if you take a snapshot of your work area and upload it for us to see.The important thing is to open the Layers Palette and see if indeed the text is in text layers. I'm wondering if your web designer gave you a flattened file, i.e., all the layers he/she created were flattened so that you have just the single layer named "Background". If this is the case you are out of luck and cannot edit the text. But you can certainly recreate the card yourself using the text tools.
Were you not even able to open the Layers Palette as I described? Please send us that snapshot. To do that, hit the Prt Scr (or similar) on your keyboard. Then from the PSE menu bar, do File > New from Clipboard. Save the file as a jpeg and insert it into a forum message via the camera icon.
Hi Mark,
ok I did ask him to make the business card where the layers I can change the
text, but he came back to me with one only is Victoria, so here the business
cards that I'm trying to change it to a post card,
also you said with the text tool I can re-create it from scrash? pls explain
because maybe I need to do so,
my business card front and back , he said we can't use the business card
basic and just re-change sizes?? this one we don't have the layers, this
company did bankruptcy...
so pls let me know what we can do? thanks
Hi Mark,
because maybe I need to do so, where is the text tool? is it T
323836 wrote:
for the camera icon, and take a screen shot, I have no idea how to do so?
In PSE make sure your picture and Layers Palette are both open. Hit the Prt Scr (or similar) on your keyboard. Then from the PSE menu bar, do File > New from Clipboard. Save the screenshot as a jpg.
Then make a PSE forum message. To insert the screenshot, click the camera icon. Click the From Your Computer tab, then click Browse to navigate to the folder where you saved the screenshot jpg. Select the screenshot and click Upload.
The Photoshop Elements trial is not crippled. You have the full function of Photoshop Elements thru your trial period. If you did not get a layered business card template and the place you used to create your card went bankrupt, you might try looking around the net for free business card templates. You can do this from scratch but it's easier with a template as it's already sized and it has a basic layout.
Templates come layered so all you need to do is double click on the T of the text layer you want to change in the layers palette and type in the desired text.
Edit: Mark was much faster at typing how to make a print screen. I'll leave all of the below anyway. ![]()
How to make a screen shot of your workspace if on Windows...
1. With your card open in the workspace and the layers panel open as I think Mark wants to see if you have a layered business card, press the print screen button on your keyboard. On my keyboard, it's located above the numeric keyboard.
2. After you press the print screen key, go to the menu and select File<New...from clipboard. A large blank document will open.
3. Press Ctrl + V keys at the same time to paste. Alternately, you can do this from the menu bar...Edit<Paste. This will paste the snapshot you took of your workspace into the open document.
4. (Optional step) You can use the crop tool to cut away unnecessary parts of your screenshot if desired.
5. Next, save the document. To make the document more forum friendly...smaller in file size, I'd use file<Save for Web but if you just want to File<Save As...it's okay. Save in JPG format so you can upload to the forum.
For the camera icon, Mark means the camera icon in the post box that appears when you post or reply to a post when using the web forum. Mark posted a screen grab with the icon but I'll add one with a red arrow pointing to the icon you click to add an image to a post.
I always save any image I want to upload to this forum or any forum to my desktop as it makes it easier to find. A dialog will come up that says choose. Press it and navigate to your JPG image. It will list the location where you have the file stored on your computer. Press the upload button to add the image to the post.
Edit: I'm not sure why Mark has a "Browse" on his button and I have "Choose". Same difference...just select whichever option your button displays.
Since it looks like you are new to PSE here are basic steps to create a business card from scratch.
1. File > New. Set the Width and Height in inches. This creates the layer named Background.
2. Click the "T" icon on the toolbar to activate the Text tool. On the tool options bar choose your font, size, color, etc.
3. Click in the blank file where you want to enter text and type away. When you are done click the Commit icon on the options bar; in my PSE version this is checkmark icon. You can also commit the text with the Enter key on the numeric part of the keypad (the Enter key on the alphabet part of the keyboard inserts a carriage return while typing text). The text is placed on a new layer. You can later change the font attributes by clicking on a text layer and going back into the Text tool.
4. Do the same to create more text. In my example I created seperate text layers for the various portions of the business card: doctors's name, phone numbers, address. I did this so that I can later reposition them separately.
5. To add the logo: I opened the logo in PSE, selected it and copied it to the clipboard, and pasted it in the business card image. This also placed the logo on a separate layer.
6. I added the horiziontal line with the Custom Shape tool, also creating a new layer.
7. Now you can resize and relocate the various layers using the Move tool.
North America
Asia Pacific
