I record directly into my sound card which means I can only input one source at a time. I've decided to treat myself and so am looking for a mixer with at least three powered XLR inputs, and USB out which will allow me to record 3 or 4 or more inputs at a time. I don't, however, have a huge budget so I'm looking at the lower end of the scale financially. Can anybody recommend anything, please?
There are very, very few that do this; mostly they just have 2-channel USB outputs, and there are only two only relatively cheap ones that I'm aware of that go beyond this. Firstly the Alesis MultiMix 8 USB 2.0 8-Channel Mixer, and secondly the Phonic Helix Board 12 Plus. Both are capable of sending 10 separate audio streams via USB2 and they are a similar price.
Phonic used to have a reputation that you wouldn't want as a manufacturer - basically for producing cheap junk, but I've been informed by a good source that things have improved considerably over the last few years, and they are now producing very good, quite innovative stuff. Alesis, on the other hand, have always had a good reputation. So don't ask me to choose, because I can't!
Thanks. The Zoom looks excellent however it's regretably out of my price range. But I'm seriously considering the Alesis MultiMix 8 USB 2.0 as here in the UK I've found one for £190, still a little more than I wanted to spend but I think it will do exactly what I want (which is to be able to record a stereo-miked piano plus one or two vocals - so 4 x 48v powered XLR ins - on separate tracks simultaneously).
I've found this one, Peavey PV 8 USB, which is at a great price.
http://www.dv247.com/studio-equipment/peavey-pv-8-usb-8-channel-compac t-mixer-with-usb-i-o--72009
But I can't find out whether the USB out is only the stereo mix or individual tracks for multi-recording. Can anybody shed any light on this? Thanks.
I do agree. As I said in my last post I've spent much of today looking up units and reading about them, and indeed the most vital bits of information - in this case how many outputs the USB handles - is often simply not given. Grrrrr!
For example, in the case of the Alesis MultiMix 8 I have discovered that there are actually two units, one £70 cheaper than the other. But can I find out whether the cheaper one handles multichannels on its USB ...???!!!
Steve G, may I ask if you are certain that the Alisis Multimix 8 USB definitely does output via USB more than just a stereo mix? I ask because I've found the user guide online and in the features description at the beginning it states "Stereo USB input and output – routes the main ouput and the 2-track return through the USB port in crystalclean, 16-bit, 44.1 kHz stereo digital audio. Use the Multimix USB as a high-quality soundcard for recording and playback with Windows and Macintosh computers.".
I'm starting to wonder whether I'm actually going to find what I'm looking for after all ... ?
I take your point, but it could be weeks or even months before such unit are out, and I need to purchase by the end of next week! I'm a bit baffled, as I would have thought that what I'm looking for would be a staple for many a home recording studio? What do you guys do when you want to record more than one input at the same time?
I think that generally there are rather more Firewire interfaces around for multitrack use than USB ones - Firewire as a protocol has advantages when it comes to streaming apps, even though in speed terms there's not a lot in it as far as USB2 and the 400 version is concerned, anyway. There are a lot of devices around that simply provide a small number of mic inputs, and extra line inputs but have no front panel mixing controls. I tend to use MOTU devices - I have a Traveler, and also an 8Pre, which doubles up as a spare set of ADAT inputs to a somewhat larger mixer. But the control app for both of these devices allows you to do monitor mixes with them, and send these to outputs. For many people though, the downside of this is that the only controls are virtual - not much use if you want to feel a set of faders under your fingers. For what I use them for it's not a problem though - it's never in live situations where it would make a difference.
But I'd say that for a compromise situation, the USB or Firewire interface bolted onto an actual mixer is quite a good way to go - it gives you more flexibility overall, because you can use the mixer as a standalone device if you want to. But it's not the norm in studios - that is to use dedicated line-input devices running from either insert points or group outputs from a larger mixer.
As for waiting for USB3 devices - well, don't. They will be ages coming, and quite frankly there won't be any real advantage in terms of having it on small mixers. You'd need a pretty hefty device to even begin to use up significant bandwidth. And on top of that, there will inevitably be a price premium on any mixers capable of using USB3, which will be even more offputting for the purchaser at the cheaper end of the market.
I only use Audition for recording at home - not for live situations, except occasionally as a backup. For most of the live recording I do (which is classical music), I use an Alesis HD24HD with external mic preamps, and leave any mixing decisions until later. Just in case anybody is horrified about the idea of multimiced multitrack classica recording, I should say that this isn't what I do! Classical stereo techniques only plus a Soundfield...
Aidan: I have a firewire interface (Presonus Firestudio Mobile) that affords me 8 inputs and 2 outputs, which I think is all I need at this point. It's an affordable and good unit that will do me fine for the foreseeable future. Before that, I had a PCI soundcard (Delta 44) and a small mixer with four inputs and four outputs. It was fine. Decide how many ins and outs you need, then buy the card or interface that's best at your price point.
I use a pci card in a desktop or a Tascam firewire interface.
I think the Alesis mixer comes in the original Multimix which is a usb 1.1 device or a Multimix usb 2.0 device which is usb 2 and does multiple tracks.
But you need to check. As I said before this is all a mess because many of the sellers publish no clear specs.
Apologies, I shouldn't have specified USB in my original post. I'm a big fan of FireWire and certainly wouldn't have any problem with using a FireWire device. Moreover I'm not insistent on a physical mixing desk, all I want to be able to do is to input up to four powered XLR sources and be able to record all four simultaneously. I'm in the UK and don't really want to spend more than £150 tops ($240). I thank you for your help, which has encouraged me to broaden my search parameters.
Sorry - should have answered this directly. According to the Alesis web page about the mixer, it does. It's the first thing in the list of key features:
"10-direct outputs to your computer for recording and 2 return inputs for monitoring"
Which seems pretty clear to me. The difference between the two versions of this mixer are that the USB version uses USB1.1, and only has two USB outputs. The USB 2.0 version though has the ten - so be careful about exactly which one you are looking at...
Thanks Steve. I must have accessed the user guide of the FX model. So ... the Alesis is within my budget (just), but now I begin to worry that I should be looking at FireWire rather than USB after all! Would you concur that FireWire would be a better avenue to go down, or do you feel that the Alesis will cope fine over USB?
I know it's going to sound strange, but I reckon that if you run a USB2 mixer straight into a single USB socket (ie, not via a hub) on a PC, you are less likely to have trouble with it than you might with Firewire. Firewire is fine once it's going correctly, but it only takes a single incompatible Firewire chipset in your PC to ruin your day, and that simply doesn't happen with USB2. Firewire is absolutely fine when it's working, but a bit of a pain when it isn't.
I've just installed a Focusrite Firewire desktop system for a friend, and absolutely the worst thing about it was having to find a PCI card with a chipset that I knew to be compatible - because there are plenty around that aren't.
I use a Firewire interface, in my case a Yamaha digital mixer with 2 MY16AT ADAT cards plus an M-Audio Profire Lightbridge.
Steve is spot on to point out that Firewire devices can be very fussy about the chipset though. For example, my M-Audio box specifies that it wants a particular TI chipset and, before purchasing anything, I made sure that the computer I wished to use use that particular interface.
Having done that, I can say that my system has been rock solid for a couple of years now.
So, if you can put together a system that works, it will likely work reliably and well. However, if you need the ability to plug into a variety of computers not always in you control, then Firewire needs to be approached with caution.
Bob
A lot depends on what OS you are running now and in the near future if something catastrophic happens to your main machine. If it were me (and I, too, work on a limited budget), I'd stick to USB2 devices.
Firewire is excellent when it all works but, if you hit problems, it's a lot more difficult to monitor and diagnose. There seems to be this thing of having to install "legacy" drivers on Windows 7 for firewire to work on many machines. USB2 has a few quirks on the newer OS's on some machines, but the workarounds are better known.
As a born pessimist, I'd also look at the returns policy of the supplier and balance it against the absolute saving of a pound or two.
More good thoughts and advice, thanks guys. Yeah, I also do a lot of video editing and for that my preference is certainly completely FireWire-biased, however I'm very pleased to see that the general consensus here is that USB should be fine for my sound interface. My PC is an HP Workstation, quad processor with 10Gb RAM and next week I'm upgrading from XPx64 to Win 7 (hence the upgrade of my sound gear as well). Here in the UK I've found the Alesis for £189 which is an excellent price, so I think I'll go out and get myself one tomorrow. Unless anyone can suggest differently ... ?!
Just to complete my story: in the end I was a very naughty boy; I went with firewire and moreover I ended up spending a lot more than I had originally intended, yesterday purchasing for myself a Mackie Onyx 1220i desk!
http://www.mackie.com/products/onyx1220i/
Happy Aidan!
Congrats!
I was just about to turn your attention to this one: http://www.zoom.co.jp/english/products/r24
This is quite a "Kinder egg" product if I ever saw one:
8 input sound card with 6 mic (with phantom) preamps. One instrument level preamp.
8 track field recorder. Records to SD card. Battery option
8 fader and 8 buttons + transport contols Mackie protocol control surface, compatible with for instance Audition...
So it's really 'three in one', and at a silly price. Add to this some basic sequencing and audio editing, drum machine (it's got touch sensitive pads too!), sampler and a tuner, and couple of spark-of-inspiration built-in mics. Somebody has been thinking, I think.
Now Zoom hasn't got a super high reputation for thier preamps (I guess the Mackie mixer above is a notch better, yes), but I've read a reputable test and it says it sounds quite good. Anyway, concidering the price, this is a steal! Just a proof that development indeed is taking place, still. This is not for everyone, but for the project studio owner this may save a lot of desk space, and not least hassle...
Very interesting, Brian, thank you. The price is certainly excellent so I OUGHT to be regretting having not seen this before purchasing the Mackie (at two thirds the price again), but I have to confess that even though I haven't got it properly up and running yet I've already fallen in love with my ONYX 1220i!
I also can't ascertain from the Zoom24 specs exactly what is outputted to the PC via USB. Again, might it turn out that this machine only exports one stereo feed at a time, and doesn't allow simultaneous recording of more than two tracks? It talks about simultaneous eight track recording, but that seems to be into its own memory, not as individual tracks to a DAW?
AFAIK, the R24 is a beefed-up R16. It will record 8 tracks at once, and play back 24 - but it only has a stereo output, so you have to mix them in the device. As an audio input device for a PC, it will let you record 8 tracks at up to 96k (limited to 48k if you want to record internally as well). Apparently the input stages are nothing to write home about, though - otherwise it would be quite a good bet for quite a few applications. Trouble is, to get the input stages better would probably cost a disproportionate amount of money, and they wanted an affordable device...
You can read the SOS R16 review online: http://www.soundonsound.com/sos/sep09/articles/zoomr16.htm
But the R24 review is still subscriber-only, unless you have the mag. All I can tell you is that they think that since Zoom only did one of the things they suggest at the end of the R16 review, it's a bit of a missed opportunity - and I'd say that I have to agree.
In an all-in-one device like this, there will always be more to add to "all". There's no stopping! Some digital connections would be nice, as would MIDI (which nobady has commented).
I follow SOS in their thought that this should be an inspiration (or kick in the a%$) for others, who could provide better preamps, longer faders etc. It would have to come at a different price though. As I mentioned, this is not for everyone. For the very small demo studio it could be perfect, for pristine recordings of acoustic instruments - probably not. But as SOS points out; this is frustrating since the unit is dead quiet (unlike a laptop) and as such an ideal tool for quiet recordings...
Hi, I am fairly new to Multi track recording, I have alway just recorded "Live" sound with an old stereo Wavelab program. Anyway I recently purchased Adobe audition 3.0 and an Alesis 16 Track Firewire Mixer. I want to be able to record all 16 tracks at once for a live setting and then go back later to edit individual tracks if necessary. My problem is I cannot get Adobe to Recognize more than 6 tracks ?..By default the program opens up with 6 tracks, All the drivers for the Alesis have been installed and I have set my Alesis Firewire 16 as the default Recording hardware but still no change in the number of tracks displayed ?
Also, if anybody out there is familiar how do you assign what instrument go to what track number ?
Thanks for any help, i really need it !!
Mike From California
I am S Raj from India. I visited this forum and see some great discussions. I am a beginner and wanted the advice of the experts,
I have with me a Alesis USB 2.0 Mixer and am looking out for Adobe Audition Software. The reason for this, is I have been using Cool Edit Pro and now with Digital Console, the old software does not sync.
I am wondering if buying Audtion Software would solve the problem, if it does then does Adobe Audition support Multi Track recording (sorry if I am using the wrong Technical word)
I appreciate any advice that I can get,
Raj
North America
Asia Pacific
