• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Build Maven KO
New Here ,
Jan 19, 2011 Jan 19, 2011
Salut,
J'ai le message d'erreur suivant après récupération du trunk ou de la release 1.2:
> maven package
[ERROR] Failed to execute goal on project flex-pmd-flex-lib: Could not resolve dependencies for project com.adobe.ac:flex-pmd-flex-lib:swc:1.3-SNAPSHOT: Failed to collect dependencies for [com.adobe.ac:flex-pmd-ruleset:jar:1.3-SNAPSHOT (compile), com.adobe.cairngorm:event-source:swc:1.1 (test), com.adobe.cairngorm:cairngorm:swc:2.2.1 (compile), com.adobe.flex.framework:flex-framework:pom:3.2.0.3958 (compile), com.adobe.flex.framework:playerglobal:swc:10-3.2.0.3958 (compile), com.adobe.flex.framework:datavisualization:swc:3.2.0.3958 (compile), com.adobe.flex.framework:datavisualization:rb.swc:en_US:3.2.0.3958 (compile), org.sonatype.flexmojos:flexmojos-unittest-support:swc:3.5.0 (test), junit:junit:jar:4.7 (test)]: Failed to read artifact descriptor for com.adobe.cairngorm:event-source:swc:1.1: Could not transfer artifact com.adobe.cairngorm:event-source:pom:1.1 from/to apache (http://cvs.apache.org/repository/😞 No connector available to access repository apache (http://cvs.apache.org/repository/) of type legacy using the available factories WagonRepositoryConnectorFactory
Quelqu'un a une idée?
Merci!
MAB
Qualixo (FR)
TOPICS
FlexPMD
Views
10.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Jan 21, 2011 Jan 21, 2011
Hi again,
I am still facing issues in maven build; below are some missing artifacts:
1) com.adobe.cairngorm:event-source:swc:1.1
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=com.adobe.cairngorm -DartifactId=event-source -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=com.adobe.cairngorm -DartifactId=event-source -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
  1) com.adobe.ac:flex-pmd-flex-lib:swc:1.2
  2) com.adobe.cairngorm:event-source:swc:1.1
2) com.adobe.flex.framework:datavisualization:swc:3.2.0.3958
      mvn install:install-file -DgroupId=com.adobe.flex.framework -DartifactId=datavisualization -Dversion=3.2.0.3958 -Dpackaging=swc -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=com.adobe.flex.framework -DartifactId=datavisualization -Dversion=3.2.0.3958 -Dpackaging=swc -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
3) com.adobe.flex.framework:datavisualization:rb.swc:en_US:3.2.0.3958
      mvn install:install-file -DgroupId=com.adobe.flex.framework -DartifactId=datavisualization -Dversion=3.2.0.3958 -Dclassifier=en_US -Dpackaging=rb.swc -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=com.adobe.flex.framework -DartifactId=datavisualization -Dversion=3.2.0.3958 -Dclassifier=en_US -Dpackaging=rb.swc -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
  2) com.adobe.flex.framework:datavisualization:rb.swc:en_US:3.2.0.3958
For reference, here is settings.xml
<repositories>
<repository>
<url>http://opensource.adobe.com/svn/opensource/cairngorm3/maven-repository</url>
<id>cairngorm3-repo</id>
</repository>
<repository>
<url>http://opensource.adobe.com/svn/opensource/flexpmd/maven-repository/release</url>
<id>flexpmd-repo</id>
</repository>
<repository>
<url>http://repository.sonatype.org/content/groups/flexgroup/</url>
<id>flexgroup-repo</id>
</repository>
</repositories>
Any help greatly appreciated.
MAB
Qualixo
Votes
Translate
Translate
Report
Report
New Here ,
As a feedback, first issue (No connector available to access repository apache of type legacy using the available factories WagonRepositoryConnectorFactory) was fixed with downgrade to maven 2.x (was on latest maven 3.x), as Maven since 3.x does not connect to legacy repositories anymore..
Votes
Translate
Translate
Report
Report
Engaged ,
Aug 01, 2012 Aug 01, 2012
I am cross referencing a similar thread that about this same issue: http://forums.adobe.com/thread/1041494
It started when I tried to build FlexPMD with Maven 3.x, then I downgraded to Maven 2.x in order to access the 'legacy' repos.  However with Maven 2.x I arrived at the same place where Qualixo arrived, so presently I am still unable to build FlexPMD until this is resolved.
Votes
Translate
Translate
Report
Report
Engaged ,
Aug 02, 2012 Aug 02, 2012
LATEST
To anyone finding this thread with a Maven 2 build error matching the above, see the previous cross referenced link.  The solution is to build from flex-pmd-java-parent intead of flex-pmd-parent.
Votes
Translate
Translate
Report
Report
