New PC and now I get a 1172: Definition error
Jan 19, 2011 9:14 AM
I am using Flash CS4 installed on my c drive. All of my flash files are on a local network. I got a new PC yesterday and now none of my files will publish without the code. The files and locations on the network have not changed. Everything worked fine before the PC was changed.
The error I get is: 1172: Definition com.caurina.transitions:Tweener could not be found.
    Jan 19, 2011 10:58 AM   in reply to brooksrv
    That is a custom class that you would have to have downloaded and placed into a location (folder named com) somewhere.  Since you are likely dealing with a new installation of Flash on your new machine, you probably need to set up the classpath to be able to find the com location.... via Edit -> Preferences -> Actionscript -> Actionscript 3.0 Settings...
    Jan 19, 2011 12:25 PM   in reply to brooksrv
    You only need to specify up to the part of the path that you don't specify in your import command, so I think you only need the following in your classpath...
    J:\Increment 2\ILS\Tech Writers\CBT\Inc_2_CBT\Working_Flash
    Jan 19, 2011 12:32 PM   in reply to brooksrv
    You're welcome
