I have a strange problem (for me, of course
I want to use a table with several columns with words. At the top of the tabe I want to insert a voice player. But when I try to wiew, the player is not in the position I want, above and at the beggining of the fourth word.
Here is link to the file (one of them, I have more and in everyone is the same.)
http://uciteljska.net/razno/Bralne_Vaje/Hitrost/SiritevVidnegaPolja_Vi dim/1_Isci/dve1.htm
Thank you for the answer.
Hi Natasa,
please look here:
Yours:
<td colspan="3"><object type="application/x-shockwave-flash" data="dewplayer.swf" width="200" height="20" id="dewplayer2" name="dewplayer"> middle:
<param name="movie" value="dewplayer.swf" />
<param name="flashvars" value="mp3%3dtop1.html" />
<param name="wmode" value="transparent" />
</object></td>
<td colspan="3" align="center"><object data="dewplayer.swf" type="application/x-shockwave-flash" name="dewplayer" width="200" height="20" align="middle" id="dewplayer2"> <param name="movie" value="dewplayer.swf" /> <param name="flashvars" value="mp3%3dtop1.html" /> <param name="wmode" value="transparent" /> </object></td> Hans-G.
Hi, Hans and thanks for the reply
But this does not solve the problem. Do you see the media in the right place on your computer? Here is the same. And I do not think this is the right solution. If the table has its properties and the word is in the right place, the media should be too, I assume. So, there must be something else. I will try to insert a table for media specialy, perheaps that will work.
Regards, natasa
Hi, Hans, thank you for your concerning.
This excersise I am doing with Hot Potatoes. It can be done like this, but I do not like the distance between the media and words. I would not like to have an information between. But it will do, if we (you
) will not find the solution about beahviour of the table.
regards and thanks again.
I will be absent for two days, so if I will not be able to reply ...
regards, Natasa
Hi, Hans,
Thank you very much for trying to help. But in this excercise all the words have 3 letters, in next excersises the words are longer and sometimes 3, 4 or more letters long. So, if the would be centered, the goal of excersise would be somehow corrupted. Student has to read the words so that they start all at the same place (this are excersises for bad readers)
so, I found that solution as I mentioned before, the space between words and media is a litle bit bigger, but it is OK.
So, perheaps Cramps or Murray know the solution of the problem?
Best regards, Natasa
North America
Asia Pacific
