When the s:TileGroup is wide enough to fit all elements in one row its still 3 rows heigh. Why isn't it dynamically adjusting it's height?
Setting requestedRowCount to 1 solves the height problem but blocks content reflowing.
This example seems to work fine:
xmlns:s="library://ns.adobe.com/flex/spark">
<s:TileGroup width="100%" height="100%">
<s:Button width="200" height="200" />
</s:TileGroup>
</s:Application>
Can you provide a small example like this that demonstrates what you are seeing?
The height of the TileGroup should be 21 (height of one button).
Code:
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
<s:Group width="400">
<s:Rect width="100%"
height="100%">
<s:fill>
<s:SolidColor color="0xff0000"/>
</s:fill>
</s:Rect>
<s:TileGroup width="100%">
<s:Button label="foo"/>
</s:TileGroup>
</s:Group>
</s:Application>
Result:
After further investigation it looks like this is a known issue.
Check out the comments in this bug: http://bugs.adobe.com/jira/browse/SDK-25495
"This is a known limitation. TileLayout is not a real re-flow layout the way text works. It doesn't go through a double-pass measure. The only way to get it to re-flow is to set explicit width on the layout's target (the DataGroup, TileGroup or Group with the TileLayout)..."
There is a minor enhancement filed to allow this to work here: http://bugs.adobe.com/jira/browse/SDK-27688
Please vote for that enhancement.
Sorry for replying 2 year after, but I was looking for smth similar, and things are not fixed in Flex4.
So I created a little function.
(It might nor work in all cases, and surely needs some improvement)
private function resizeTileGroup(tG:TileGroup):void{
var maxH:uint=0;
//For each row in tileGroup
for (var i:uint=1;i<=tG.rowCount;i++){
//increment variable with the height of the first element in row
maxH+=tG.getChildAt(i*tG.columnCount-tG.columnCount).height;
//And apply the height to TileGroup (added with verticalgap multiplied by rowCount)
tG.height=maxH+tG.verticalGap*tG.rowCount;
In case of the TileGroup being generated dynamically, one can dispatch the event like this.
myTileGroup.addEventListener(FlexEvent.CREATION_COMPLETE,resizeTileGroup)
private function resizeTileGroup(e:FlexEvent):void{
var tG=e.currentTarget;
var maxH:uint=0;
var elt=tG.getChildAt(i*tG.columnCount-tG.columnCount);
maxH+=elt.height
North America
Asia Pacific
