How to?
I've got a ton of Mac .caf audio files sitting in Garage Band that I want to use in Premiere for PC. I can get them on the PC, but Premiere can't use them--at least in its current state. Is there any way to use them WITHOUT having to convert to WAV or MP3?
Try changing the extension to .AIF or .M4A; no idea if that will work, but I suspect this is just an Apple-tastic custom container for PCM or AAC audio. If that doesn't work, you'll probably be able to open them in Audacity and convert them.
I'm only familiar with Garage Band by name, but I would anticipate that it would have several file format/CODEC options. What are the other ones?
Also, is .CAF possibly a format for perhaps loopology? See the replies down this THREAD.
Sounds a bit like SmartSound's formats, that allow the SmartSound Libraries to be used in their programs, or plug-ins, and is not a format that other programs can use, however, one can easily Export to PCM/WAV from, say Sonicfire Pro 5.
You might just have to use the CAF files IN Garage Band, then Export from it.
[Edit] Here is another THREAD on CAF files, and using Garage Band to do the conversions. Be sure to scroll past the ads and download buttons.
Actually, your earlier suggestion of Audacity is one that appeared in several threads on CAF files. That would be one of my next choices, if Garage Band does not work with CAF files, and Export/Save_As PCM/WAV, though it sounds like it does.
Good luck to the OP,
I might have figured out a way to losslessly batch convert these so that they'll open up in Premiere; let me know if you didn't find another solution.
I only have one test file I'm working with, and it sounds like there is some variability in what is actually packaged in the CAF file, but it's worth a shot... free, too!
No worries
Before I go all crazy with a tutorial for something that doesn't work, do you have a short sample of one of the files that I could play with? Doesn't need to be more than a few seconds; shoot me a PM if you have an upload location or I can give you access to my FTP. If it's less than 5-10MB, email would work too.
As mentioned, I've found that there is all sorts of variability in these files; this is predicated on my research, but not actual testing. I only have one to work with at the moment, and while I thought you could find EVERYTHING on the Internet, apparently CAF files are exempt from that rule ![]()
Cool; got 'em, and they'll work with my solution! I'm assuming you're doing this on Windows, but it should work on a Mac too.
The conversion should go very quickly, because there is no re-encoding happening. MPEG Streamclip is simply splitting the CAF container open, extracting the streams, and rewrapping them in an MOV container. They'll also be named the same as your originals. The CAF files are encoded with the Apple Lossless Audio Codec, which is a legitimate codec in QuickTime, on Windows, and even in Premiere, but the CAF container cannot be split open by anything but QuickTime (at least on a PC). MPEG Streamclip is an extremely capable front-end for QuickTime; it does just about everything QuickTime Pro does (and more, like batching) for free.
EDIT: Actually, I just noticed that your CAFs were encoded with AAC audio; the test clip I had was ALAC. Nevertheless, they import just fine.
Anyway, you will end up with a pile of MOVs with no video, but with ALAC audio streams. These import perfectly well into Premiere, and you'll have done so losslessly; compare the file sizes and you'll see that they are within a few KBs of the CAF files.
Hope that works for you!
Well, that worked! You're awesome!
My coworker got it to work following your suggestions. I haven't tried it yet, but from what I hear everything is working.
One slight modification was to not export to a MOV but to a MP4 because our audio manager can't listen to MOVs. (Media Monkey).
Thanks so much for your help!
I LOVE YOU!!!! Just made the switch from Final Cut Pro (Mac) to Premiere Pro CS5 (Windows) and thought I lost all of my audio content from Final Cut Suite. This saved the day!!! Thank you so much. Love free tools, honest advice, and people going out of their ways to help others.
Another way to do this without compression (I assume MP4 would attempt compression) would be to change Step 5:
Currently step 5 is to choose "save as" and then choose "MOV" or "MP4" (video containers).
You can instead choose "Export Audio" and then choose AIFF (or AAC, MP3, or MP2). Guaranteed working in Premiere Pro CS5. Doing the rest of the conversions now!
Thanks again guys for this awesome thread and the help.
Glad you found it useful
I'm all about flying, stabby ninja stuff like this ![]()
Actually, this is backwards: the reason I suggested MOV (and Toomany countered with MP4) is because the Save As options don't recompress--the Export options do. This mirrors the Save As vs. Export functionality in QuickTime Pro. The Save As option will simply rewrap the existing streams into a new container; Export recompresses the stream (even if you set the settings to be exactly the same) and puts it in a new container.
Another option in this would be to use the Save Track > Save Audio Track command; that will extract just the audio to an M4A file, which will indeed import into Premiere Pro as well.
Have fun!
North America
Asia Pacific
