Hi there,
I'm currently wondering around XMP metadata and swf files.
A: Flash CS5: works
When I use the XMP panel in Flash CS5 and export a swf, open Adobe Bridge CS5 and select the file, the XMP data are correctly displayed.
B: Flash Builder(Flex 4.1): don't work
When I use Flashbuilder and add my metadata to the compilation, then compile, open Adobe Bridge CS5 and select the file, nothing is included in metadata.
Procedure based on the following (same problem if metadata are directly set through compiler arguments):
http://livedocs.adobe.com/flex/3/html/help.html?content=compilers_14.h tml
../src/config/ProductMetaData.xml
<flex-config>
<metadata>
<title>My title</title>
<description>My description</description>
<publisher>The publisher</publisher>
<creator>The creator</creator>
<language>EN</language>
</metadata>
</flex-config>
compiler argument
-load-config+=config/ProductMetaData.xml
As far as understood, on the background the following is added to the swf at compile time:
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
<rdf:Description rdf:about='' xmlns:dc='http://purl.org/dc/elements/1.1'>
<dc:format>application/x-shockwave-flash</dc:format>
<dc:title>My title</dc:title>
<dc:description>
<rdf:Alt>
<rdf:li xml:lang='x-default'>My description</rdf:li>
</rdf:Alt>
</dc:description>
<dc:publisher>The publisher</dc:publisher>
<dc:creator>The creator</dc:creator>
<dc:language>EN</dc:language>
</rdf:Description>
</rdf:RDF>
I've checked that the medata is correctly added to the swf file using this small software polarswf:
http://download.cnet.com/Polar-SWF-MetaData/3000-6676_4-10738623.html
I do not know if it is safe to use it in a produciton context at least in trial mode it allows to check the metadata included in your swf.
I wonder if this metadata coonot be read by Adobe Bridge because they are at a "lower level" than those put by flash CS5 XMP panel?
Thank you in advance for your help.
This is not a blocking situation, but I'm curious to understand what happend.
Cedric Madelaine (aka maddec)
I was following this post for a LONG time, since I noticed the same problem.
This week I was getting in it into myself again and I noticed you use load-config. I used these compiler options :
| contributor name | Sets metadata in the resulting SWF file. For more information, see Adding metadata to SWF files. |
| creator name | Sets metadata in the resulting SWF file. For more information, see Adding metadata to SWF files. |
| date text | Sets metadata in the resulting SWF file. For more information, see Adding metadata to SWF files. |
But that resulted in this XML string where the dc namespace was missing a / on the end of the URI
That caused the metadata which was added in flashbuilder was only visible in bridge in the rawXML panel, and not the specific fields
changing the URI in http://purl.org/dc/elements/1.1/ did the trick ( did this in bridge by exporting the rawXML, changed the / , and imported it )
</rdf:Description>
</rdf:RDF>
Sadly there was no way I could add this / myself everytime.
BUT then I discoverd this option :
| raw-metadata XML_string | Defines the metadata for the resulting SWF file. The value of this option overrides any metadata.* compiler options (such as contributor,creator, date, and description). This is an advanced option. |
And you could give the exact RAW XML as you described
<rdf:Description rdf:about='' xmlns:dc='http://purl.org/dc/elements/1.1/'>
<dc:description>
<rdf:Alt>
</rdf:Alt>
</dc:description>
</rdf:Description>
</rdf:RDF>
to the compiler. This could also be done in Flash with JSFL.
In the end I wrote an ANT script which injects the exact XMLstring of metadata to Flash and Flex projects by using the raw-metadata parameter in FLEX and JSFL for flash.
Hope this helps
North America
Asia Pacific
