<Bryan\>
CFSQLTYPE CF_SQL_INTEGER
Jan 24, 2011 9:03 AM
Using ColdFusion 9/Standalone, Access database
Can anyone tell me what this error means (CFSQLTYPE CF_SQL_INTEGER)? I received it while processing a simple form. Is it related to the data being processed or something to do with how the field is defined in Access?
Thanks!
    Jan 24, 2011 9:05 AM   in reply to
    Could you post the code used and the full error message?
    Jan 24, 2011 9:32 AM   in reply to
    <input type="hidden" name="QQS_ID" value="#GetDetail.QQS_ID#">
    The error means the value provided for QQS_ID is not an integer.  It looks like you are missing <cfoutput> tags around the input field. So the field literally contains the string "#GetDetail.QQS_ID#", not the value of that variable.
    WHERE QQS_ID = #url.QQS_ID#
    As an aside, it is good to get into the habit of using cfqueryparam on all query parameters.
