nstopak
Another concurrency issue?
Jan 25, 2011 8:26 AM
Here's another failure that seems related to processing batches larger than one file at a time.  Has anyone else seen this?
Failure Time----Tue Jan 25 11:01:09 EST 2011
source location ---- Reason of failure is-----[com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] [com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] The transaction is not active!
java.lang.IllegalStateException: [com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] [com.arjuna.ats.internal.jta.transaction.arjunacore.inactive] The transaction is not active!
at com.arjuna.ats.internal.jta.transaction.arjunacore.TransactionImple.c ommit(TransactionImple.java:223)
at org.jboss.ejb.plugins.TxInterceptorCMT.endTransaction(TxInterceptorCM T.java:501)
at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxIntercep torCMT.java:411)
at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:1 81)
at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor. java:168)
at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFacto ryFinderInterceptor.java:138)
at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:6 48)
at org.jboss.ejb.Container.invoke(Container.java:960)
at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalPro xyFactory.java:430)
at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSes sionProxy.java:103)
at $Proxy158.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:143)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.inte rcept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.procee d(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.inte rcept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept( InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept (AuthorizationInterceptor.java:188)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterc eptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineI mpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMes sage(AbstractMessageReceiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessa geDispatcher.java:225)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(A bstractMessageDispatcher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:2 08)
at com.adobe.idp.jobmanager.execution.workadapter.AbstractExecutableJob. invokeRequest(AbstractExecutableJob.java:127)
at com.adobe.idp.jobmanager.execution.workadapter.PersistentExecutableJo b.execute(PersistentExecutableJob.java:60)
at com.adobe.idp.dsc.workmanager.adapter.UnManagedAsynchronousWorkAdapte r.run(UnManagedAsynchronousWorkAdapter.java:39)
at org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java:204)
at org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrapper.java: 275)
at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExec utor.java:743)
at java.lang.Thread.run(Thread.java:619)
    Apr 18, 2011 10:44 AM   in reply to nstopak
    I have seen this problem when the barcode decoder fails to find any barcodes in the current document so the transaction fails. You will need to handle the failure itself by creating a route or wrapping the decode service in your own code.
    Apr 18, 2011 11:08 AM   in reply to nstopak
    The best place for code examples would be the Quickstarts here:
    http://help.adobe.com/en_US/livecycle/9.0/programLC/help/index.htm?con tent=000448.html. A custom DSC that uses the decode service would probably give you the control you were looking for but I thnk the delay you may be experiencing in the decode is the decoder "trying" to find the barcode on the page. ie: rotating the page, looking again. etc. So the wrapper would help you handle the error better but not the delay. For that you could place a timeout on the decode service itself. Have the decode service time out if it takes more than 60 secodes to decode on a page.
    Apr 18, 2011 11:09 AM   in reply to nstopak
    By the way, make sure you are specifically searching for only the type of barcode you have on your documents. i.e.: don't check off all the barcode boxes.
