I installed the latest blueprint plugin 1.3.0 on adobe flex builder 3 version 3.0 build 3.0.2 and received the below error in the log:
Any help would be appreciated!
Could not create action delegate for id: com.adobe.flexbuilder.blueprint.mxmlaction
Tue Jan 25 14:58:57 CST 2011
Plug-in com.adobe.flexbuilder.blueprint was unable to load class com.adobe.flexbuilder.blueprint.EditorActionDelegegate.
java.lang.ClassNotFoundException: com.adobe.flexbuilder.blueprint.EditorActionDelegegate
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(Unkno wn Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(Un known Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(Unkno wn Source)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(Unk nown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createEx ecutableExtension(Unknown Source)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutable Extension(Unknown Source)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecuta bleExtension(Unknown Source)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createE xecutableExtension(Unknown Source)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(Unknown Source)
at org.eclipse.swt.custom.BusyIndicator.showWhile(Unknown Source)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Unknown Source)
at org.eclipse.ui.internal.PluginAction.createDelegate(Unknown Source)
at org.eclipse.ui.internal.PluginAction.runWithEvent(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection (Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.access$2(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Unknown Source)
at org.eclipse.ui.internal.Workbench.runUI(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.internal.ide.IDEApplication.run(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Un known Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(Unknown Source)
at org.eclipse.core.launcher.Main.run(Unknown Source)
at org.eclipse.core.launcher.Main.main(Unknown Source)
Error
Tue Jan 25 14:54:12 CST 2011
Plug-in com.adobe.flexbuilder.blueprint was unable to load class com.adobe.flexbuilder.blueprint.Activator.
java.lang.ClassNotFoundException: com.adobe.flexbuilder.blueprint.Activator
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(U nknown Source)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(Unknown Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
at org.eclipse.ui.internal.Workbench$21.run(Unknown Source)
at org.eclipse.core.internal.jobs.Worker.run(Unknown Source)
