gwbores
Can't see preferences dialogue box
Jan 26, 2011 9:40 AM
When I click on the button, the dialogue box does not appear and the program is locked up until I hit escape.  Before I do that it "pings" when I click elsewhere.
    Jan 26, 2011 10:19 AM   in reply to gwbores
    Most probably Illustrator puts the dialogue box on a second monitor that once was attached to your computer. There are tricks to get the box back, you might do a search in the forum. This problem was discussed several times
    Jan 26, 2011 10:32 AM   in reply to gwbores
    gwbores,
    If you have no cherished preference settings, you may reset the preferences (Ctrl+Alt+Shift/Cmd+Option+Shift during startup) and get things to look the way they did when you met Illy.
    One of the ways suggested is to increase resolution to a silly value, move the box into the cluster of others, and reduce again.
    Harron normally suggests a less silly way (not silly enough for me to remember straight away), but he is busy right now.
    Jan 26, 2011 12:28 PM   in reply to gwbores
    You are welcome, Greg.
    Aug 16, 2012 2:35 PM   in reply to Jacob Bugge
    Jacob, the resolution trick worked for me. THANK YOU for suggesting it.  I already had my resolutions set to the maximium amounts, so I did the reverse, and set the main monitor to the lowest value.  When I then reset it to the maximum, the Preferences Box innocently enough showed up on screen.
    Aug 16, 2012 2:43 PM   in reply to JoyrideSF
    You are welcome, joyrideSF, and thank you for the added knowledge in your solution.
