Download Flash/AIR for Android, where?
Jan 27, 2011 11:35 AM
When I go to Adobe's download center I don't get an option for Android download.
So from where exactly I can download Flash player and AIR for Android ?
    Jan 28, 2011 1:59 PM   in reply to mari8899
    Jan 31, 2011 8:22 AM   in reply to eidnolb
    Guess I misunderstood you question.
    You can install flash player and AIR in android from Market.
    Jan 31, 2011 9:10 AM   in reply to mari8899
    Hi, This is an Update of 1/24/11 for Flash Player for Android. There are system requirements and other info here:
    http://kb2.adobe.com/cps/860/cpsid_86018.html
    eidnolb
    Jan 31, 2011 11:39 AM   in reply to mari8899
    Hi, The Adobe Website is very extensive, not every program can be in one place. Not every mobile phone meets the system requirements, so it wouldn't be fruitful to have Flash Player in the download center. It would have to be qualified, if you have this, or if you have that, and etc. and etc. and that is what the last Adobe website link that I posted does.
    Even I have to use the Search feature to find some things. As I said tho, the Manufacturer of your Android has a website and should have up to date information. Likewise your Carrier.
    There is a lot of difference also between Flash Player for various computers and the mobile phones.
    eidnolb
    Feb 6, 2011 4:08 PM   in reply to mari8899
    I cant describe how angry I am with adobe now.. It is an hour I have been trying to get air for my android tablet. I know I can get it from android market but at the moment it doesnt work and I cant really understand why guys you dont simply put air for android into your site. You talk like there are hundreds platforms and it is impossible to deliver air from adobe web site for android but it doesnt make sense at all.... a software is not available in its creator web page... ridiculous.
    Jul 8, 2011 5:18 PM   in reply to mari8899
    Apps written for Android using Adobe Air, at start of installation, will most times direct the user to download the Adobe Air runtime from either the Amazon apps marketplace or the Android marketplace, depending on where the user downloaded the app. The iPhone version app will have the runtime already bundled, so there will be no need to install a separate Air runtime in most cases. Flash player is a different software together, which allows you to view and enjoy Flash sites. Flash 10 and Air for Android are two different items.
    You can always go to Android market or Amazon marketplace first and install the latest Air runtime. This is only requiered once, and not for every Air app that you install. Hope this helps.
    Nov 2, 2011 5:05 PM   in reply to mari8899
    Adobe Flash Player and AIR for Android are available directly from the Android Market on supported Android devices.  If you are unable to find Adobe Flash Player in the Market, the most likely reason is that your device does not meet the minimum system requirements.
    Specifically, Flash Player requires a CPU with support for the ARMv7-A instruction set to achieve the level of performance required for acceptable multimedia playback.
    Your device has an ARM11 CPU, which only supports the ARMv6 instruction set.
    For future reference, Adobe maintains a list of devices certified to work with Adobe Flash Player and AIR here:
    http://www.adobe.com/flashplatform/certified_devices/
    You might want to give Skyfire a try.  It uses "remote desktop" technology to render Flash animation and video in the cloud, for devices that are incapable of processing Flash content natively:
    https://market.android.com/details?id=com.skyfire.browser&feature=sear ch_result
  • darkcrayondrogba
    Feb 8, 2012
    Feb 8, 2012 11:53 PM   in reply to mari8899
    Flash Player 11 will be supported indefinitely on Android devices.  It is perfectly capable and can play all content authored for Flash player 11 and under (in other words, everything until it is possible to make Flash player 12 content- even then people can publish down, as you have always been able to do with Flash).
    The player handles videos, 3D acceleration, data loading/manipulation, bitmap and vector animation, audio/mp3 playback and audio transformation- etc., etc., etc. Crowing that 'Flash is dead' on mobile seems very easy/trendy to do- but it is not  true or accurate. Adobe has committed to update Flash so that it works on 'future versions' of android tablets (and Playbook).However, Flash mobile will die a slow but steady growth as developers see no point to use it and new versions of flash software comes out and will move to Air and/or HTML5. Check it at engadget.com:
    http://www.engadget.com/2011/11/11/adobe-releases-final-flash-player-v ersion-for-android-blackberr/
    Mar 1, 2012 12:02 AM   in reply to mari8899
    Why not choose a ESPOW android tablet pc?
    I can run all my phone apps on my tablet. So it takes up full screen which is fine since there is a button which shows the most  recent apps so its very easy to switch apps running in the background. I think Flash is still very important in the tablet form factor since web browsing is the most important thing u do with tablets and u wont get a full experience not having flash.
    Jun 13, 2012 5:38 AM   in reply to mari8899
    You can also have a try for ctutu China Tablet PC .
