Alex_Cissokho
Problem with Play Pause AS3 button on main timeline
Jan 28, 2011 5:46 AM
Wondered if anyone can help with this? Have been trying to create a play/pause button for the main timeline in my flash movie.
Created a movie clip with 1st frame - a pause graphic, then on 2nd frame - play graphic, labelled the frames 'pause' and 'play' consecutively and put a stop action on the first frame of the movieclip.
Then put the following code in the actions layer of the main timeline (and gave instance name of 'ppBtn' to the movieclip):
var pp:Boolean = true;
function ppState(event:MouseEvent) {
if(pp) {
stop();
event.target.gotoAndStop('pause');
pp = false;
}else{
play();
event.target.gotoAndStop('play');
pp = true;
ppBtn.addEventListener(MouseEvent.CLICK, ppState);
It works in stopping and starting the movie but the actual movieclip doesn't toggle between the pause and the play graphics (just stays on the 'pause' state - 1st frame). Any help on this much appreciated!
thanks
    Jan 28, 2011 5:56 AM   in reply to Alex_Cissokho
    try:
    if(pp) {
    stop();
    ppBtn.gotoAndStop('pause');
    pp = false;
    }else{
    play();
    ppBtn.gotoAndStop('play');
    pp = true;
    Jan 28, 2011 5:59 AM   in reply to Alex_Cissokho
    a working sample:
    http://www.flashdersi.com/flash/diger/adobeforum/2state.fla
    with your unchanged codes...
    Jan 28, 2011 6:26 AM   in reply to Alex_Cissokho
    Which answer was helpful (correct) ?  Could you mark it?
    Apr 12, 2012 3:02 AM   in reply to Hakan KIRIK
    Hakan
    After Googling for hours I came across your post and downloaded your simple example 2state.
    Absolutely spot on for my needs, nice & simple.
    Have found many complex solutions, but none as straight forward as yours.
    Have adapted it and pleasantly surprised it does not cause issues with external AS3 file already attached (to load mysql via php) as other solutions have.
    I am a newbie to AS3 which is a minefield compared to AS2, great post.
    May 22, 2012 1:16 PM   in reply to Hakan KIRIK
    I just tried this and got a memory error. It worked fine the first time, and now it doesn't work any more?
    Dave
    May 22, 2012 1:36 PM   in reply to Hakan KIRIK
    here's my new issue. I restarted and got it to work, but now the timeline stops and doesn't start. I'm getting this in my output window:
    ArgumentError: Error #2109: Frame label pauseButton not found in scene pauseButton.
              at flash.display::MovieClip/gotoAndStop()
              at myLibertyMobile_fla::MainTimeline/ppState()
    and here's all the code I'm using:
    if(pp) {
    stop();
    event.target.gotoAndStop('pauseButton');
    pp = false;
    }else{
    play();
    event.target.gotoAndStop('playButton');
    pp = true;
    rewind.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame);
    function fl_ClickToGoToAndPlayFromFrame(event:MouseEvent):void
              gotoAndPlay(1);
    May 22, 2012 1:46 PM   in reply to Hakan KIRIK
    ok, this is solved. There is something that was left out here... when I created my play and pause graphics, they came in as movie clips. They can't have a place for an instance name because for some reason the code looks for that.
    Dave
    May 19, 2013 7:25 AM   in reply to Hakan KIRIK
    Hi there, any chance you still have this working example? I am having a problem with my play/pause button and I'd love to see a solution that actually works!
    Thank you in advnace!
