I am simply selecting my text in my html document and then selecting "Open Browser Window" from the Behaviors panel. I then put in the info for the file I want it to open along with the size, etc...
When I test it in the browser (Safari) the link works but the rollover features don't show ... it doesn't show as a link in the browser window. I followed the tutorial exactly and the instructor's browser showed the link as a rollover. It's driving me a bit crazy.
I'm using CS5 on the latest version on Mac OS (Snow Leopard).
I can put up an example if needed.
Thanks so much for any assistance.
BC
Safari can be stubborn. Clear the Cache, either from the Safari Menu or by pressing command + option + E.
When using Safari as the preview browser, it's helpful to set check Disable Caches in the Develop Menu. If the Develop Menu does not show in the Menu Bar, open the Preferences, go to Advanced and check Show Develop menu in menu bar.
Thanks for your reply but neither of those seemed to do anything.
First, I get the same occurrence in Safari and Firefox. The link will open the new window but it doesn't behave like a link with rollover behavior. The link doesn't even show in the document window before previewing tin the browser.
Second, I do not see an advance tab anywhere in my Preferences. Just to be clear, I'm on Mac.
Thanks again and hopefully you or someone can dig a bit deeper. Again, I'm happy to post an example if need be.
BC
For best answers, we need to see a link to your page, or post your CSS and HTML code into the forum reply using >> Syntax highlighting, plain.
Without seeing your code, I'm guessing you have applied the onClick behavior to something other than an anchor <a> tag.
Your code should look something like this:
<a href="javascript:()" onclick="MM_openBrWindow('some-link.html','','resizable=yes,width=400,height=400')">Some link</a>
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
http://alt-web.com/
http://twitter.com/altweb
My son helped me figure it out. For some reason Dreamweaver was not inserting the "#" symbol into the link area of the property inspector. Once I put that in manually the open browser window link works properly all the way around.
Also, I misunderstood the place to look before for the advanced tab for the cache settings... I thought they meant in Dreamweaver preferences but in fact they meant Safari. I apologize for that mixup.
In any case I think it might be a flaw that Dreamweaver does not insert the "#" automatically for a open browser window behavior. Any ideas on that?
But ay least my problem is somewhat solved.
Thanks all,
BC
The pound symbol is kind of a placeholder for hyperlinks. It makes links behave like links when you don't - yet - have a real link to put there. If DW would insert it by default, it may generate more confusion that not inserting it does.
Yep, I was referring to the Safari Preferences. Sorry for not specifying that.
It's not a flaw in DW.
There are several ways of creating a trigger point for an open window behavior and a null link (#) - a link that doesn't actually go anywhere but only exists to fire a Javascript behavior in browsers - is one of the least preferred.
A real link plus a "return false" in the Javascript is more accessible.
See
Thanks guys.
Just a follow-up comment --
The video tutorial I watched show the instructor add a open browser window behavior to a text link. As soon as she did that it placed the "#" symbol in the link window of the property inspector by default. Now, she was in Windows and I am in Mac. But my system does not place that "#" in automatically like hers did. I am trying to determine why hers would and mine wouldn't. Is it Windows verses Mac?
I feel this is a valid issue because I am a fairly experienced DW user and was able to troubleshoot and figure it out with some help from the forum here. But I could easily see a beginner hitting a brick wall here if the it didn't work properly.
Comments would be so welcome.
Thanks again,
BC
Sorry but it is a DVD tutorial.
It's from this series:
http://www.video2brain.com/en/products-20.htm
BC
The null link must have been in place prior to the behavior being applied.
The behavior inserts Javascript inside an existing HTML tag.
If it's applied to text already wrapped with an <a> tag then you get
<a href="#" onclick="MM_openBrWindow('','','')">hello</a>
If there is no link (<a> tag), just plain text, then the Javascript is inserted inside the <p> tag (if there is one).
<p onmouseover="MM_openBrWindow('','','')">click me</p>
If there are no <p> or <a> tags, the Javascript is inserted into the <body> tag.
<body onload="MM_openBrWindow('','','')">
I watched the tutorial again carefully and soon as she selects the text to apply the behavior the "#" appears in the link area of the property inspector. She makes no mention of it at all some one assumes that it inserts automatically.
I understand completely the purpose of the # but is it possible that Windows automatically outs the "#" in automatically and Mac doesn't? That's all I'm trying to determine.
BC
I'm using CS5 on Win 7 and, when I'm using the behavior, at no point does DW insert the "#" automatically.
All the behavior does is insert the Javascript code.
I have to manually select an existing HTML tag on the page to which the behavior is applied (<a>, <p> etc)
I am having the same problem but it looks like Dreamweaver is inserting the pound sign. If you go to apartmentanchor.com/clear-lake/park-at-armand-bayou.html and click on the floor plans tab, then click one of the floor plans, it works on this page. But if you try to do the same on a different page in a different folder: apartmentanchor.com/katy-pages/residences-at-cinco-ranch.html, and click on the floor plans tab, and then click one of the floor plans, it redirects to my home page. I don't understand why it works on one page and not the other and it is the same code???
I'm not sure what's going. The files are all in the correct folders. These links all worked at one point in time and then stopped working over time. the code looks like this:
<td><a href="#" class="fpbutton" onclick="MM_openBrWindow('../floorplan-pages/spring/10145-floorplans/ 594-square-feet-10145.jpg','','width=414,height=376')">594 Square Feet</a></td>
All I can tell you is that when you browse to that link URL, you do not see a JPG image, you see this page -
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Apartment Anchor - Free Apartment Locating Service | ApartmentAnchor.com</title>
<style type="text/css">
.content {
width: 400px;
a {
font-size: 20px;
</style>
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-25512543-2']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
</script>
</head>
<body>
<div class="content">
<ol>
<li><a href="http://apartmentanchor.com/blogs">Houston Apartment Blog</a></li>
<li><a href="woodlands/woodlands-tx-apartments.html">Woodlands Texas Apartments</a></li>
<li><a href="clear-lake/clear-lake-tx-apartments.html">Clear Lake Texas Apartments</a></li>
<li><a href="cypress-texas/cypress-tx-apartments-for-rent.html">Cypress Texas Apartments</a></li>
<li><a href="river-oaks/houston-river-oaks-apartments.html">Houston River Oaks Apartments</a></li>
<li><a href="spring-texas/spring-apartments-for-rent.html">Spring Texas Apartments</a></li>
<li><a href="league-city/league-city-tx-apartments.html">League City Texas Apartments</a></li>
<li><a href="houston-texas-apartment-search-engine.html">Houston Apartment Search Engine</a></li>
<li><a href="get-availability-information.html">Get Apartment Listing</a></li>
</ol>
</body>
</html>
Do you have that page on your site? Is that your home page?
Perhaps you have some hidden redirection going on via an htaccess file? I dunno....
Yes, This is my home page. I called Go Daddy and they couldn't figure it out. They were thinking it had something to do with my folder names but then recanted that idea. I don't have any redirects so I don't know what's up....Guess I'll keep searching for a solution or get a professional to look at it.
North America
Asia Pacific
