Wookie
Export search results to excel file (php)
Feb 1, 2011 3:42 AM
I've got a search results page and I want to have a button on that page that when clicked exports the search results as a CSV file.
I've managed to get the button to work using this javascript:
<script>
function getcsv(){
window.location="getcsv.php";
</script>
<input type="button" onclick="getcsv()" value="Get a CSV File!">
This is the code for 'getcsv.php' below.
I understand that the code below the line highlighted in orange needs to be modified. At the moment it is just pulling the data from the 'install_tbl' (see line highlighted in red)
How do I change the code so it creates the excel file from the search results instead?
<?php require_once('Connections/conn_OSR.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch ($theType) {
    case "text":
      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case "long":
    case "int":
      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case "double":
      $theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
      break;
    case "date":
      break;
    case "defined":
      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return $theValue;
$colname2_rsSearchResults = "-1";
if (isset($_GET['site_name'])) {
  $colname2_rsSearchResults = $_GET['site_name'];
$colname4_rsSearchResults = "-1";
if (isset($_GET['project'])) {
  $colname4_rsSearchResults = $_GET['project'];
$colname3_rsSearchResults = "-1";
if (isset($_GET['job_no'])) {
  $colname3_rsSearchResults = $_GET['job_no'];
$colname_rsSearchResults = "-1";
if (isset($_SESSION['MM_Username'])) {
  $colname_rsSearchResults = $_SESSION['MM_Username'];
mysql_select_db($database_conn_OSR, $conn_OSR);
$query_rsSearchResults = sprintf("SELECT * FROM joinversion5 WHERE site_name = %s AND username = %s OR job_no = %s AND username = %s OR project LIKE %s AND username = %s", GetSQLValueString($colname2_rsSearchResults, "text"),GetSQLValueString($colname_rsSearchResults, "text"),GetSQLValueString($colname3_rsSearchResults, "text"),GetSQLValueString($colname_rsSearchResults, "text"),GetSQLValueString("%" . $colname4_rsSearchResults . "%", "text"),GetSQLValueString($colname_rsSearchResults, "text"));
$rsSearchResults = mysql_query($query_rsSearchResults, $conn_OSR) or die(mysql_error());
$row_rsSearchResults = mysql_fetch_assoc($rsSearchResults);
$totalRows_rsSearchResults = mysql_num_rows($rsSearchResults);
// DB Connection here
$select = "SELECT * FROM install_tbl";
$export = mysql_query ( $select ) or die ( "Sql error : " . mysql_error( ) );
$fields = mysql_num_fields ( $export );
for ( $i = 0; $i < $fields; $i++ )
$header .= mysql_field_name( $export , $i ) . "\t";
while( $row = mysql_fetch_row( $export ) )
$line = '';
foreach( $row as $value )
if ( ( !isset( $value ) ) || ( $value == "" ) )
$value = "\t";
else
$value = str_replace( '"' , '""' , $value );
$value = '"' . $value . '"' . "\t";
$line .= $value;
$data .= trim( $line ) . "\n";
$data = str_replace( "\r" , "" , $data );
if ( $data == "" )
$data = "\n(0) Records Found!\n";
header("Content-type: application/octet-stream");
header("Content-Disposition: attachment; filename=your_desired_name.xls");
header("Pragma: no-cache");
header("Expires: 0");
print "$header\n$data";
mysql_free_result($rsSearchResults);
