Hi
I tried a simple Flex Mobile Application using Flex 4 Burrito + AIR 2.5 + Android Emulator.
Code is really simple just a hello World Application which displays HelloWorld in a Label,
once I run this file in my bin-debug I get the swf and descriptor.xml file relavent file for my
application.
Then Use flex Release build I generate a certificate name.p12 file and then it generates a .apk
file too, then I tried to package these files (swf+apk+descriptor.xml) using the command line
adt -package -target apk-emulator -storetype pkcs12 -keystore "certificatename" "apkfile" "xmlfile" "swffile"
I get success
then I goto the the dir in which the apk is present and gave the following command in cmd
adb install "filename.apk"
after this on my emulator I get the file but if I launch the file I get the following error
"The Application "app-name" has stopped unexpectedly-Force Stop"
Can someone giveme a solution
North America
Asia Pacific
