Do you have the optional Twain_32.8ba plug-in installed in order to access a scanner?
If I recall correctly (some days that's not a certainty), I think there's a bug in some scanner drivers that manifests as a failure with other seemingly unrelated functions (I think a failure of File - Automate is most common, but it could be causing a problem here as well).
-Noel
Headscratcher83 wrote:
Hi Everyone,
Creating a new user account finally did the trick! Thanks for all your suggestions.
David
Hi, When I created a new Photoshop user ID following your instructions, the problem persisted. Instead of renaming the old prefs. should I just delete them altogether or does Photoshop ignore old prefs. anyway?
David
David
First you wrote the new user id worked now you write the problem persisted. Your confusing me what is going on???? Exactly what did you do??? It sounds like you tried messing with the new user id Photoshop preferences. I did not tell you to do anything the the new user ID??????
North America
Asia Pacific
