MarkRoberto
"Acrobat does not allow connection to" Security Block
Feb 3, 2011 11:19 AM
Hello,
I hope you guys can help me with this problem.
I have a PDF embedded in an HTML page using the <OBJECT></OBJECT> tags. The PDF has several buttons whose actions are Mouse Up/Open a File. These files are other PDF documents in the same folder as the PDF that is opened. When I click a button, I get a Security Block error message that says: "Acrobat does not allow connection to:" and then the full path to the file that I'm trying to load, "file:///G:/"etc. The dialog box does not let me use a relative path.
I am using IE8 and Adobe Reader X but I know that this problem also occurs with Reader 8.
I've tried changing the Open a File action to Open a Web Link and using a relative path to either an HTML page or a PDF and this doesn't work. Everything I try has been met with the "Acrobat does not allow connection to" error message.
Please, any help you can provide will be appreciate.
Cheers,
Mark
    Feb 24, 2011 7:39 AM   in reply to MarkRoberto
    Did you get an answer on this?  I am encountering the same problem.
