How do I merge layers/objects in Illustrator?
Feb 8, 2011 10:13 PM
In photoshop I can easily merge layers when I get too many. But I can't find this function in Illustrator. I'm using a dot grid for colouring and I have to duplicate the image/object to grow the grid. But now I have tons of layers that are slowing down my computer and preventing it from saving the AI file. I've tried grouping the objects but it just puts the multitude of layers in a sublayer which doesn't help.
Does Illustrator have a merge layer option that will take a bunch of objects and merge them into one object?
Thank you for your help.
    Feb 8, 2011 11:21 PM   in reply to Maegwin
    The Layers Panel in Illustrator is actually a "Layers and Objects" panel. It not only shows layers, but can show all objects as well. If you see things labeled <path> then it's an object, not a layer.
    Chances are you are seeing the objects. When you Group objects it collects them in to a <Group>, which is like a sublayer but still seen as an object which is why it has the < and > brackets.
    A great many objects will indeed slow down illustrator. There's no real way to get around the slowdowns when you hit them. The best you can do is turn off visibility of objects that aren't needed at the moment. The more things that must be drawn, the slower the app gets. It's been this way for years with complicated files.
    Until Illustrator is made 64-bit and possibly multi-threaded more, there's not much that can be done.
    Feb 9, 2011 4:29 AM   in reply to Maegwin
    If it's an option, you could manually flatten parts of the image by selecting a bunch of objects and letting AI convert it to bitmap data...
    Mylenium
    Feb 9, 2011 5:42 AM   in reply to Maegwin
    this would only help if the objects are overlapping each other. Are they?
    Feb 9, 2011 10:08 AM   in reply to Maegwin
    You may try a pattern fill instead. There are some examples for it in the swatches libraries. You can re-color them or create your own.
    Feb 9, 2011 3:13 PM   in reply to [scott w]
    Quoted for emphasis.
    Monika's suggestion of using pattern fill is a very good one. A shape with a pattern fill is seen as a single object.
    Feb 9, 2011 3:33 PM   in reply to Maegwin
    There is an option you might find handy, even though in this situation Monika might have a superior way of handling this process.
    From the Layers flyout there is show layers only, it does not show the dots as separate paths but as a collective layer.
    As you have it set up now
    After the option is selected you get all of this and one layer no paths showing
    Feb 9, 2011 3:57 PM   in reply to Wade_Zimmerman
    That merely changes what's displayed in the Layers Panel. It won't help with slowdowns.
    Feb 9, 2011 4:15 PM   in reply to [scott w]
    Well actually yes and no, it all depends on what is slowing you down and what the OP needs, so it might be something they are not aware of and could help them navigate and make using the layer panel speed up and keeping it uncluttered, easy and quick to scroll through on the other hand it may not be what the OP is looking for in which case they will continue to seek other ways to make what they want work.
