Making Adobe PDF with From Field Non-Savable
Feb 9, 2011 8:33 AM
Hello,
I'm using Adobe Acrobat Professional ver 9 and have created an accessible course certificate form with a fillable field.  The user brings up the certificate, types their name in the field, and prints the certificate.  When they do this, the form gets updated with their name even if they didn't save it.  So the next person that brings up the form sees the previous persons name.
Is there a way to have the user type their name in the field, print the certificate, and not have the name saved in the field?  I'd like it if every time someone brings up the certificate that it's a fresh copy.
Thank you.
  • George Johnson
    Aug 11, 2002
    Feb 9, 2011 8:42 AM   in reply to srigel1
    Is this an online PDF? What version of Acrobat/Reader are you seeing this behavior in?
  • George Johnson
    Aug 11, 2002
    Feb 9, 2011 9:05 AM   in reply to srigel1
    That's odd, it shouldn't do that. Can you post a link?
  • George Johnson
    Aug 11, 2002
    Feb 9, 2011 10:30 AM   in reply to srigel1
    So it's not being served by a web server, but rather a file server? If so, set the file to be read-only and don't allow users to switch it back to read-write.
  • George Johnson
    Aug 11, 2002
    Feb 9, 2011 11:59 AM   in reply to srigel1
    A web server will send a copy of the file to the client machine, so it's a separate file. Any changes the user makes cannot affect the file on the web server.
    There are different types of file servers, but at its simplest it allows shared file access to other machines on the network. If it doesn't control how files are saved, anyone with access to a shared file will be able to overwrite it.
