How can I rotate a document and save?
Feb 9, 2011 10:55 AM
I use Adobe
Reader 8 and cannot rotate and save documents? Can anyone help?
    Feb 9, 2011 11:54 AM   in reply to CADMAN3D
    Hello,
    I am not sure whether rotate feature is there in Adobe Reader 8
    This feature is included in Adobe Reader 10
    You can download Adobe Reader, just click here : ftp://ftp.adobe.com/pub/adobe/reader/win/10.x/10.0.0/en_US/AdbeRdr1000 _en_US.exe
    Save it and run, it will install Adobe Reader 10
    Once it launched click on View (From Menu bar on Top) and then click on Rotate View -> As per your choice
    Screen shot attached :
    Then you can Click on File and "Save As" -> PDF
    Hope this is helpful
    Vikram
    Feb 9, 2011 1:26 PM   in reply to VikramGaur
    View>Rotate View only saves the view for the current session. When you reopen the document, it will open up the way it was before rotating.
    Reader cannot make that sort of changes and save them.
    Feb 10, 2011 1:59 AM   in reply to ~graffiti
    Hello,
    That will be a change for that current session and Adobe Reader is a software which is used view PDF
    If you want to make changes then you need Acrobat X, which is used to edit PDF
    Vikram
    Apr 1, 2011 6:30 AM   in reply to CADMAN3D
    Apr 1, 2011 7:56 AM   in reply to crina_ca
    The above post refers to Acrobat and not Reader.
    Apr 1, 2011 8:20 AM   in reply to ~graffiti
    I gave him a solution to edit pdf. files
    Apr 1, 2011 8:41 AM   in reply to crina_ca
    And to avoid confusion, I just pointed out the fact that it had nothing to do with the product that they have.
    (We've already mentioned that it can be done in Acrobat).
    Mar 15, 2013 8:24 AM   in reply to CADMAN3D
    Install a pdf file printer driver and print the rotated file to the "pdf" printer. It will ask you for a file name to "print" to. The "printed" file will open in the correct orientation.
