no OCR parameter in "File Type Settings"
Feb 14, 2011 2:27 AM
The following knowledge base article suggests that there used to be an "Use OCR" parameter in the"File Type Settings" of LiveCycle PDF Generator:
http://kb2.adobe.com/cps/402/kb402622.html
Where is this feature now located?
I want to do OCR on full page sized TIFF images or PDFs with page filling TIFF images embedded.
The output format should be PDF.
I am running a TRIAL of "LiveCycle Enterprise Suite 2" Service Pack 2 Version 9.0.0.2.20100902.2.246889 including
ADOBE® LIVECYCLE® PDF Generator ES2
ADOBE® LIVECYCLE® Barcoded Forms ES2
ADOBE® LIVECYCLE® Reader Extensions ES2
ADOBE® LIVECYCLE® Rights Management ES2
ADOBE® LIVECYCLE® Process Management ES2
    Feb 14, 2011 4:44 AM   in reply to irgei
    Its in the File Type settings on the Generator service page in adminui
    Feb 14, 2011 4:33 PM   in reply to irgei
    I'm not sure why you are not seeing it.  It should be on the image to PDF  screen.  Its a switch that says Use OCR.
    Mar 29, 2011 12:06 PM   in reply to Hodmi
    Even I am not able to see the options where I can specify if I want to use OCR. I have Adobe Livecycle ES2 SP2 installed on RHEL 5 (64 bit).
    We also tried to export the configuration file and edit it manually to set useOCR from "false" to "true" and upload it back. But still it did not work.
    I could not search any text in the PDF.
    Can you please help.
  • Axel Bangert
    Jul 6, 2011
    Aug 5, 2011 10:56 PM   in reply to irgei
    Dear Combattands,
    this forum is censored. I already informed the CEO. Drop me a line by email.
    Best regards
    Axel Arnold Bangert - Herzogenrath 2011
  • Axel Bangert
    Jul 6, 2011
    Aug 7, 2011 11:15 AM   in reply to irgei
    Hi Irgei,
    take ABBYY OCR SDK in combination with iText pdf SDK. The Abbyy OCR  delivers by dfar better quality - especially dewarping-
    and it is fully automatable.
    Best regards
    Axel
