Fade in Fade Out between slides
Feb 14, 2011 3:12 AM
I am using Adobe Captivate 5 and putting together a demo to show screen recording alongside video.
This has been split between several slides. My problem is that for each slide, I have 'No transition' selected, yet when it plays (either in  preview or when I publish to SWF and HTML), there is a fade out/fade in to each slide.
I have tried to look over the settings to see if there was a default setting that managed this but I can't find an option to prevent the fade out/fade in so that the entire project plays seamlessly.
    Feb 14, 2011 4:21 AM   in reply to KomalV
    Recording also adds different types of objects to your Captivate project, other than the slide alone. If any of the other objects have transition setting to "Fade in and Out", it's possible that the slide will have the same transition effect.
    Please run through your project to see if there are any such objects and reset them to No transition.
    And, there is a simple way to do this. From the Object Style Manager (Edit-> Object Style Manager), choose the object for which you want to change the transition effect, and modify the same parameter under tranistion. Set it to no transition. Do this for all object types in your recorded projects. Publish/Preview, should now work fine.
    Please try this and let me know if it works.
    Sushma
    Feb 14, 2011 12:58 PM   in reply to KomalV
    Hello and welcome to the forum,
    It will indeed be due to objects that are set to fading transitions. Just want to add that by default the first slide in a project fades in and the last slide fades out. You can change that in the Preferences, Project, Start and End.
    Lilybiri
    Feb 15, 2011 4:09 AM   in reply to KomalV
    Hello,
    Is there eventually a possibility to check your file? If yes, you could post it on acrobat.com and send the link?
    Lilybiri
    Feb 17, 2011 9:25 AM   in reply to KomalV
    Hello,
    I had a look, and it seems to me that the issue is specifically with the FLV's, especially with those that were 'greenscreen' recordings. Is this correct? I played some of them separately and could even see the fading out there. How were they created and imported in Captivate?  Was always looking for a transition in CP itself, but apparently the fading effect has not its origin there.
    Lilybiri
    Feb 17, 2011 11:34 AM   in reply to KomalV
    Hi there,
    could you try to import the flv files to the library first and apply them then to the slide?
    Best TD
    Feb 17, 2011 11:16 PM   in reply to KomalV
    Hi KomalV,
    From the video files you posted, it is seen that the videos infact have no fade in fade out transitions. I created a sample project on my side using the video files and published them. The project played without the transition effect. We would need to investigate your cptx in order to probably figure out what is causing this.
    Is it possible to mail me  your project, or a sample of your project, where you see the same issue to sushma@adobe.com ?
    Sushma
    Feb 21, 2011 5:10 AM   in reply to KomalV
    Hello,
    If it was due to a transition effect on the Master slide, it is really easy to change this to No Transition: look on the Master slide Panel, probably there is something inserted (image?) with a transition effect, and you get its Properties in the Property panel. In the Properties you have the Transition accordion, change the Transition just like you would do for a normal slide. In this screenshot you see an example, with an image on the Master slide.
    Lilybiri
    Mar 2, 2013 2:57 PM   in reply to Lilybiri
    Fantastic! I have spent so much time trying to figure this out! Thank you for the simple fix.
