Acrobat Reader X crash when printing
Feb 14, 2011 9:47 AM
  Latest reply: AnuLan, Mar 15, 2013 7:37 AM
Replies 1 2 Previous Next
    Feb 21, 2012 3:27 AM   in reply to brian.hart
    ManishPali actually put me on the right path, I had this error now too (even tried creating a text only pdf as my pdf's had a jpeg embedded) and I resolved by changing the "Enable Protected Mode at Startup", then under Security(enhanced) I unchecked "Enable Enhanced Security" as well and this resolved my issue, hope it helps people going forward.
    Feb 21, 2012 7:39 AM   in reply to brian.hart
    workaround isn't a solution, what about all the people who faced the problem but think it is the printer driver the cause ?
    why nobody from Adobe can't reply, or then .. release the new version ?
    for sure, the easiest way is to suggest another pdf reader for now.
    Feb 21, 2012 8:59 AM   in reply to darynv
    Thanks very much for taking the time to research and reply to my pdf printing problem with Adobe X. I will reload X and give your suggestion a try, tonight.
    Feb 21, 2012 10:52 AM   in reply to brainfight
    You are right a work around is not the solution! At first I thought it was the printer driver but the printer was relatively new. I will take your advice and stick with Adobe Reader 9.4 and wait for someone at Adobe headquarters on King Street in San Francisco to wake up and fix the problem with their reader X software.
    Feb 29, 2012 8:23 AM   in reply to brian.hart
    Just so you know, Adobe - this issue has just recently reared it's ugly head on my own pc: when trying to print (hit print button or otherwise attempt to print) Adobe X (fully updated as of today's date) immediately crashes. Doesn't matter which printer is set as default, local or network. When I take off the protected mode thing, it's fine.
    This is a machine running XP SP3, also fully updated.
    I haven't tried it on the other machine, running Windows 7, but I know it was working last week, so I'll letcha know!
    Mar 6, 2012 5:22 PM   in reply to brian.hart
    I had this problem and tried everything you people suggest, but none of it helped.
    I renamed the user's local profile to username_OLD and had her log back in. This fixed the problem.
    Corrupt profile.
    Mar 20, 2012 8:03 AM   in reply to brian.hart
    Same problem with Adobe X crashing on multiple machines in multiple locations, all trying to print on a network printer.  Disabling protected mode seems to be the solution.  This bug is more than a year old, why isn't it fixed???
    Mar 21, 2012 3:11 PM   in reply to brian.hart
    I had this problem of Reader X hanging up when printing to Brother MFC-9840-CDW via PC-Fax v.2 (which is a fax program).  Reader X did not hang up when printing to the Brother MFC-9840-CDW as a printer or when printing to a HP LaserJet 220dtn.
    The AdobeReaderPatch10.1.2_cpsid_92870.exe did not help but disenabling Protected Mode at startup resolved the hanging up of Reader X when printing to Brother MFC-9840-CDW via PC-Fax v.2.
    Mar 22, 2012 8:26 AM   in reply to brian.hart
    I find it very, very upsetting that Adobe Tech Support has ignored this problem for over one year.
    I have experienced this very same problem on dozens of PCs that where upgraded to Reader X.
    To quote a previous writer "This bug is more than a year old, why isn't it fixed???"  Over one year has gone by.
    This demonstrates that Adobe does not really care about users of Adobe Reader X.
    Adobe Reader is not suitable anymore for corporate use.  Far too much support required to maintain end user problems.
    Can someone suggest another product from another vendor that we can use in place of Reader X?
    Thank you.
    Mar 22, 2012 8:36 AM   in reply to routerswbellnet
    the worst part, is to offer help to fix it , by providing details, but nobody cares, so should we change to another reader ? what alternative do you suggest ?
    Mar 30, 2012 11:00 AM   in reply to brian.hart
    Yea, had the same issues, but with almost 260 Citrix servers.  Created package using the customization wizard where I turned off the enhanced security "Protected Mode at Startup", EULA, and all the other stuff you don't want your users messing with and deployed to our test farm and it functioned like a dream.  Last week I applied the recent security updates 10.11 and 10.12 and everything look fine, however, I will have to admit that I didn't kill a tree testing the printing fuctionality.  Well, I'm into day two of updating my production farm with this new version of Reader and it's security updates along with latest updates for Flash and Shockwave.  I'm about 85% done when the phone starts ringing off the hook, it's our Help Desk which  is getting calls from users stating they can't print.  I test and sure enough as soon as I hit the print button, Reader crashes.  I checked my test farm and same thing is happening there where I was able to print prior to the security updates.  So I spend the next two hours un-installing 10x  and re-install the 8.2.6 version we have been using without issue for as long as I can remember till I can get a handle on things.  Run through my install again with the custom mst file, it works, install the security patch and it is now broken.  Seems the security updates over-write your custom settings.  I now have a post install script that sets the application and security settings to the state that I want them.
    We didn't upgrade to 9x on our Citrix farm due to all the horror stories I read about  on the Citrix and Adobe forums.  When is Adobe going to address the original issue with 10x, why does your application crash when you try to print with the default security settings.  Please fix-it!
    Mar 30, 2012 11:53 AM   in reply to brainfight
    It's pretty sickening.. they're angling to get tens of thousands of dollars from corporations that need a reliable PDF reader and now the current version is crashy.  They know it is, and they're choosing not to fix it except for paying customers.
    Mar 31, 2012 5:50 PM   in reply to routerswbellnet
    "Can someone suggest another product from another vendor that we can use in place of Reader X?"
    "so should we change to another reader ? what alternative do you suggest?"
    Yes, as a matter of fact this is exactly what I did - for it's what should always be done when there is a superior or equal alternative (without defect) to an inferior or defective product, I switched. It took about two days of getting used to, and now I know I will never return to Adobe again.  The one I switched to, available free or paid (which gives further capabilities), is actually much more awesome than Adobe's product, at least for my uses.
    This product allows me to mark up pdf files, along with many other functions that the free version of Adobe does not permit.
    It is called pdf-xchange-viewer. It is free (or paid) for both personal and commercial use.
    Here is its homepage: http://www.tracker-software.com/product/pdf-xchange-viewer.
    I think it blows Adobe out of the water, but at the very least it is an equal, an equal from which at least the user is able to print their documents without issue.
    (Also, and this is just a bonus, I use another program called "PDF Split and Merge" to merge various PDFs, which is also free and also a great product offering services that Adobe's free version does not.)
    Good luck and happy trails saying goodbye to Adobe.
    Lol, this only sounds like an ad, but I promise, it is not!!
    Apr 5, 2012 5:38 PM   in reply to brian.hart
    There are a couple of workarounds posted here http://forums.adobe.com/message/4142897#4142897.
    In short, you can turn on "Sharing" in the printer properties, and give it a "Share Name"...should print OK after that. It worked for me.
    Cain
    Apr 6, 2012 7:03 AM   in reply to CainQ
    Adobe has a hotfix for the 10.1.2 patch which works.  Tested on our DEV and UAT farm with a script that does a silent install of the hotfix and re-sets the registry value to Enable Protected Mode.  So far so good.
    News at 11!
    Jack Motley
    CSX Technology
    904 633-5749
    RNX 633-5749
    Re: Acrobat Reader X crash when printing
    "Failure lies not in falling down. Failure lies in not getting up."
    Apr 9, 2012 5:08 AM   in reply to TrainCrash
    unsubscribe
    Olivier Gagnon
    Spécialiste Applications Bureautiques
    GIT
    Tél. : 514 393-8000 x 2937
    SNC-Lavalin inc.
    Aug 6, 2012 10:11 AM   in reply to brian.hart
    Ran into the same issue you were experiecing, have you checked the Default Printer?  Once I defaulted the user's printer to one of the office printers, Adobe X stopped freezing.  Switched it back to their home printer, which was not connected, the freezing returned. For giggles, I defaulted to a couple of the non-Adobe PDF Printers, freezing returned.
    Aug 6, 2012 2:23 PM   in reply to ModrallITDepartment
    I am a personal user and my printer is set accordingly.  My problem was not in printing; my problem that my bank statement would not download in IM 9.  I gave up this morning and went back to IM8
    Mar 15, 2013 7:37 AM   in reply to ManishPali
    Even with 'Enable Protected Mode..' unchecked I am getting the below error in my Application event log. I use Adobe Reader 11.0.2 in Windows 7 with IE 9 to view PDF forms -
    Faulting application name: AcroRd32.exe, version: 11.0.2.0, time stamp: 0x511eacd6
    Faulting module name: AcroRd32.dll, version: 11.0.1.36, time stamp: 0x50d0b924
    Exception code: 0xc0000005
    Fault offset: 0x0006a4ec
    Faulting process id: 0x880
    Faulting application start time: 0x01ce218774519977
    Faulting application path: C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AcroRd32.exe
    Faulting module path: C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AcroRd32.dll
    Report Id: b2649438-8d7a-11e2-89ec-84d7e7c9833f
1 2 Previous Next
Bookmarked By (1)
