Hello SMP Team,
I'm trying to pleace my current OVP based player with Strobe (I love the skinning features!).
I'm trying to figure out the JavaScript event that get fired when a video has ended?
Is there anyway to have the play log all the events? So far I have only figured out how to log the ready states using the following code:
function onJavaScriptBridgeCreated(playerId)
player = document.getElementById(playerId);
var state = player.getState();
console.log(state)
I'm not sure if this is all ready implmented or set for a planed release, but ideally these events could be accessed using jQuery's .bind() function.
Thanks for the help!
I'm not sure if this is the right way to do it, but I figured out how to listern for events.
When you embed your Flash file using swfobject.js, make sure you set the javascriptCallbackFunction flashvar. The demos make this confusing by calling it a param, but it's actually a Flashvar.
var flashvars = {};
flashvars.src = 'http://osmf.org/dev/videos/cathy1_HD.mp4';
flashvars.poster = 'http://www.google.com/intl/en_ALL/images/srpr/logo1w.png';
flashvars.javascriptCallbackFunction = 'onJavaScriptBridgeCreated';
flashvars.controlBarAutoHide = false;
var params = {};
params.allowFullScreen = 'true';
var attributes = {};
attributes.id = 'strobeMediaPlaybackId';
attributes.styleclass = 'smp-video-player';
attributes.name = 'strobeMediaPlaybackId';
swfobject.embedSWF('/flash/StrobeMediaPlayback.swf', 'no-flash-content', '100%', '100%', '10.1.0', '{}', flashvars, params,attributes);
Then in your JavaScript file you need to setup the callback function:
var player = document.getElementById(playerId);
player.addEventListener("complete", "completeFunc");
The above JS code will get feed the 'playerID' from Flash. The 'addEventListener' takes 2 arguments. The first is the event to listen for, the second is the JS function to run when the event is detected.
For demo's sake, set your completeFunc to be this:
function completeFunc() {
console.log('Complete!')
Now when the player reachs the end of the video, the console will log 'Complete!'.
You can see all the events by looking in the Flash source files. Look for the file 'src/player/StrobeMediaPlayback/src/org/osmf/player/configuration/Jav aScriptBridge.as'. At version 1.5.1 they start around line 262.
Now I just need to figure out the following:
Thanks for the help.
Hi all !
I tried the tip above without using swfobject, and it doesn work for me.
I'm using the StrobeMediaPlayback_1.6.238M-full version, checked the events code as posted above, and it seems correct, and though all functions get called, the event doesn fire.
You can check it at: http://www.danielcuberta.com/v2/
This is the embed code for the player, as generated by the demo configurator (wrapped for readability):
<object id="player61" width="440" height="394">
<param name="movie" value="http://www.danielcuberta.com/v2/strobe/StrobeMediaPlayback.swf"></param>
<param name="flashvars" value="
javascriptCallbackFunction=onJavaScriptBridgeCreated&
src=http%3A%2F%2Fwww.danielcuberta.com%2Fvideos%2Fvideos%2Finicio.flv& #038;
skin=http%3A%2F%2Fwww.danielcuberta.com%2Fv2%2Fstrobe%2Fskin%2Fskin.xm l&
autoPlay=true&
controlBarAutoHideTimeout=1"></param>
<param name="allowFullScreen" value="true"></param>
<param name="allowscriptaccess" value="always"></param><param name="wmode" value="direct"></param>
<embed src="http://www.danielcuberta.com/v2/strobe/StrobeMediaPlayback.swf" name="player61" type="application/x-shockwave-flash"
allowscriptaccess="always" allowfullscreen="true" wmode="direct" width="440" height="394"
flashvars="javascriptCallbackFunction=onJavaScriptBridgeCreated&
autoPlay=true&
controlBarAutoHideTimeout=1"></embed>
</object>
And this my javascript:
player='foo'; function completeFunc() { console.log('Video Complete!'); } function onJavaScriptBridgeCreated(id) { console.log(id); if (player == 'foo'){ //to attach the listener only once player = document.getElementById(id); console.log(player); player.addEventListener("complete", "completeFunc"); } }
Any hint?
I'm not sure if this will work without SWFobject.
What does your console.log('id') retrun? Is the playerID coming in as 'player61? I doubt it.
player='foo';
console.log(id);
Hi again !
Actually yes, it's player61. You may see it now in firebug's console.
I had to finish posting and go out really quick before and couldn't clean the code and leave the logs on.
I modified the configurator to output a random id just in case many videos have to be embedded in the same page. I'll have to use some time-date function to obtain unique ids later on.
This is the output right now:
player61
player61
player61
player61
(and so on till the video ends)
I'm gonna keep trying to solve this, Thanks for your quick reply !
This is part of the relevant code, I think,
initializeEventMap();
// We are ready, notify the javascript client.
mediaPlayer.addEventListener(MediaPlayerStateChangeEvent.MEDIA_PLAYER_STATE_CHANGE, onMediaPlayerStateChange);
mediaPlayer.addEventListener(AudioEvent.MUTED_CHANGE, onVolumeChange);
mediaPlayer.addEventListener(AudioEvent.VOLUME_CHANGE, onVolumeChange);
mediaPlayer.addEventListener(TimeEvent.DURATION_CHANGE, onDurationChange);
mediaPlayer.addEventListener(TimeEvent.CURRENT_TIME_CHANGE, onCurrentTimeChange);
mediaPlayer.addEventListener(TimeEvent.COMPLETE, onComplete);
mediaPlayer.addEventListener(SeekEvent.SEEKING_CHANGE, onSeekingChange);
mediaPlayer.addEventListener(LoadEvent.BYTES_LOADED_CHANGE, onBytesLoadedChange);
mediaPlayer.addEventListener(DisplayObjectEvent.MEDIA_SIZE_CHANGE, onMediaSizeChange);
exposeProperty(strobeMediaPlayback.configuration, "src", false);
exposeProperty(strobeMediaPlayback, "error", true);
ExternalInterface.addCallback("setCurrentTime", mediaPlayer.seek);
ExternalInterface.addCallback("play2", mediaPlayer.play);
ExternalInterface.addCallback("stop2", mediaPlayer.stop);
ExternalInterface.addCallback("load", load);
call([javascriptCallbackFunction, ExternalInterface.objectID, "onJavaScriptBridgeCreated"], false);
// var javascriptObjectName:String = "javascriptObjectName";
// call(["$javascriptObjectName.triggerHandler('loadstart')", ExternalInterface.objectID]);
// call(["$javascriptObjectName.trigger('timeupdate')", ExternalInterface.objectID]);
I'm hanging the file in: http://www.danielcuberta.com/v2/wp-content/JavaScriptBridge.as
Did you find any other good player out there?
I like this one quite much. The skining configuration is great and simple, and though examples are a bit complex, they are quite full featured. If only we can solve this "simple" things.
So the compete event is in there, I'm not sure why your function has stopped working then. I would try it without the player == foo test just to be sure.
I ended up using OVP, but it's terrible too. If you are building this for use on just one site, and you don't mind a cheap liecnse fee, then JW Player or Flowplayer are a million times better built and documented. Both have fully working JS API's and are very easy to use.
Strobe is the best bet for a white label Flash Player that is free. Hopefully they can get the JavaScript API up to speeed and get some proper documentation or examples built out sometime soon.
-Drew
Hi Drew !
I tried your suggestion and it's all the same now the output is:
I might be testing to see if it works using swfobject, or if there is a newer version up for download.
If nothing works I might be trying this next: http://videojs.com/
Well, I'm finished for today. I'll come back as I get ahead with it.
Thanks for all the feedback !
-Sergio
Currently working on the HTML5 Fallback Video.
From the <video> i can catch the "complete" events w/o problems. I do need the fired Events also from the SWF. via the OSMF.
I do have the swfobject.js, the video plays perfectly.
I do even get call for the function onJavaScriptBridgeCreated(playerId) . In the Console.log.
But i cannot assign an EventListener to the Object.
My Log for the console.log(player); == the SWF.Object // looks fine for me
console.log("Bridge OK") // fires while video is playing.
console.log(player); // i do get log. output
alert("Peter") // it doesnt fire.
console.log('Complete!');
alert("COMPLETE")
<div id="Fl_videoDiv">
<video width="400"
height="300"
controls="controls"
id="html5Video"
poster="media/image.jpg">
<source src="media/video.mp4" type="video/mp4"/>
<source src="media/video.theora.ogv" type="video/ogg"/>
Error! No detection!
</video>
</div>
var flashvars = {};
flashvars.src = "video.mp4";
flashvars.controlBarMode = "floating";
flashvars.poster = "xxxx.jpg";
var params = {};
params.allowfullscreen = "true";
params.allowscriptaccess = "always";
attributes.id = 'Fl_videoDiv';
attributes.name = 'Fl_videoDiv';
swfobject.embedSWF("http://myDomain.com/media/StrobeMediaPlayback.swf", "Fl_videoDiv", "400", "300", "10.1.0", "expressInstall.swf", flashvars, params, attributes);
var ticker = 0;
var running;
var video = document.getElementById('html5Video');
var player='foo';
//CALLBACK EXTERNAL INTERFACE VON DER SWF
alert("Peter")
alert("COMPLETE")
video.addEventListener('ended', function () {
$('#clock_output').append("(" + "ENDE" + ");");
this.ticker = 0;
window.clearInterval(running);
$("#slider").slider("disable")
}, false)
video.addEventListener('play', function () {
$('#slider').show();
video.muted = true;
alert("OI")
$(function () {
$("#slider").hide();
$('#slider').slider({
range:"min",
value:50,
min:0,
max:100,
animate:true,
step:5,
slide:function (event, ui) {
$("#wert").val(ui.value);
start:function (event, ui) {
startTick();
stop:function (event, ui) {
var newVal = ui.value;
$('#clock_output').append("(" + ticker + "," + newVal + "," + "mo" + ");");
function startTick() {
running = window.setInterval("tick()", 1000);
function tick() {
ticker++
function tickerstop() {
this.ticker = 0;
</script>
North America
Asia Pacific
