Colin Noble
Adobe Reader X doesn't work.
Feb 17, 2011 8:39 AM
I've downloaded Adobe Reader X based on the installation advice of Adobe.
The reader does not function at all, I cannot open any pdf file or open the program itself.
I have uninstalled and re-installed the program several times.
Although I only need the Reader, I note that Adobe AIR is being installed too.
I'm running XP Professional; I'm not computer literate enough to know how to solve this issue.
Any advice would be appreciated.
Thanks.
    Feb 17, 2011 8:55 AM   in reply to Colin Noble
    Same thing happened to me and now I'm pissed because it was working just fine before the stupid update.
    Feb 17, 2011 1:17 PM   in reply to Colin Noble
    I experienced this issue with a computer at the office, which was running Windows XP SP3. Turns out that the program was somehow set to run in compatibility mode for Windows 95.  Once I corrected this, the program operated normally.
    Hope this helps.
    Feb 17, 2011 1:43 PM   in reply to Colin Noble
    I didn't have problems either before today. I restored my computer to an earlier time before I did the upgrade and that solved the problem for me.
    Feb 18, 2011 6:47 AM   in reply to Colin Noble
    The easiest way is to right-click the shortcut to Adobe Reader on the desktop and select Properties.  From there go to the Compatibility tab and make sure none of the checkboxes are checked.  You should also be able to do this from the link in Start -> All Programs if you do not have a desktop shortcut.
    Nov 2, 2011 6:50 PM   in reply to Colin Noble
    http://www.pretentiousname.com/adobe_pdf_x64_fix/
    "...the installer had a mistake which meant the preview handler did not work on 64-bit systems.
    It turned out the problem could be fixed via a simple registry change. The change is described below and a small program which performs the fix is also provided for your convenience.
    Unlike the thumbnail fix, described below, the preview handler fix should no longer be needed by most people, since Adobe have finally fixed their installer, but it's still provided in case it helps repair things. If you had Adobe Reader installed under Vista and later upgraded to Windows 7 then you will probably still need to run the preview handler fix once to clean up a registry value which Adobe set inconsistently between the two OS versions. If in doubt, run the fix and it will tell you if anything needs to be done. If everything is good already then the preview handler fix won't change anything."
    Hope that helps. I have the same problem.
