Paula recently posted a summary of the rounded corner CSS and I'm unable to find it. How about doing it again, PZ?
Also, what's the best workaround you've found for IE?
Ignoring it entirely. :-)
.htc works on simple layouts, but Al Sparber is going to spank me for mentioning it.
http://alt-web.com/DEMOS/CSS-Rounded-Corners.shtml
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
http://alt-web.com/
http://twitter.com/altweb
Hi Murray,
my favorite in this case:
http://forums.adobe.com/message/2957388#2957388
Sorry, the discussion did get a little 'off-topic', but that is also what these forums are for.
What everyone is saying is that yes, it can be done, but not in a reliable cross browser method. Even using tables has its problems which is o/k for personal web site, but not for commercial sites that you may construct.
The idea of using images is at the moment the most cross browser method, but using css3 and letting IE6-8 display without the drop shadow would be the simplest.
PZ
Hans-G.
I'm telling!
Tattletale. ![]()
This may not be what Paula posted, but it summarizes border-radius syntax for Opera, WebKit and Mozilla.
http://www.the-art-of-web.com/css/border-radius/
Nancy O.
Hi Murray
I will re-do a post on the subject, as the thinking has changed a lot over the last few months, especially since the release of the jQuery Mobile framework, and the use of things like htc as a 'fix' for IE<9 is now the recommended norm, (as this is then ignored by IE9, so no IECC required).
Paula
Hi Murray
I have created a dreamweaver cookbook item for this, (will be easier to find and edit as thinking on this changes).
The link is - http://cookbooks.adobe.com/post_Rounded_Corners___Border_Radius__css3_ and_IE_versi-18564.html.
Hope this helps, and if you, (or anyone else) have any comments/recommendations regarding the item please let me know.
Paula
Hi Murray
IE9 can support rounded corners on any corner by using the corner specific mark-up:
border-top-left-radius : Radius_value;
border-top-right-radius : Radius_value;
border-bottom-right-radius : Radius_value;
border-bottom-left-radius : Radius_value;
You can find examples of most of the new css3 properties supported by IE9 here - http://msdn.microsoft.com/en-gb/ie/ff468705.aspx#_CSS3_BG_Borders, along with other information specific to IE9.
As for the htc or jQuery fixes for older versions of IE, I would advise applying these to the lowest number of corners/items possible.
Paula
Bring up the topic on our private forum and ask Gerry to explain the
shortcomings to you. We've analyzed Microsoft VML years ago. It's like
using the Forges of Hephaestus to make a thumbtack.
Progressive enhancement. If a client cannot accept that, then a designer
is not doing an adequate job of explaining things. But if a designer
accepts a hack like this without understanding the drawbacks, then he or
she probably is incapable of educating a client.
Al Sparber - PVII
Dreamweaver Menus | Galleries | Widgets
http://www.projectseven.com/go/hgm
The Ultimate Web 2.0 Carousel
Yes, the HTC is using VML. Also, inside the HTC file is, um, a
javascript ![]()
There is no other way to do border radii without images in IE8 and
under. The VML is actually drawing a picture, much as you would do with
SVG. Actually, SVG is one of those things where folks followed
Microsoft, but changed the name so as not to curtsy to the evil empire.
It was, however, never intended for this purpose. It is a hack and it
can easily come unglued on complex pages.
Al Sparber - PVII
Hi Murray
As I say in the article, (and as pointed out by Al) all the IE none css3 methods rely on vml, (without using images and divs) and one uses them only after a lot of testing as they may have an adverse affect on functionality.
But even though I agree with Al, in that one should opt for the 'progressive enhancement' approach for IE < 9, if one must support IE < 9 then their use is the only simple x-IE-browser method and no worse than using svg for backgrounds, (supported in IE9 and Opera, and will be supported in FF and webkit).
PZ
Hi Paula,
VML is creating elements - and that's what creates the stability issues.
Those created elements, which create the curves, need to be redrawn as
the document dimensions change - which could be due to resizing the
window or adding content or using a widget. It is not as simple as you
seem to think.
jQuery plugins like some of the tooltip ones that use VML to create
rounded boxes for IE go way, way further than this little script inside
the HTC file to ensure the curves stay with their parent. And the jQuery
tools that use this method create constraints that limit their features.
We know, believe me ![]()
Al Sparber - PVII
Hi Paula,
Thanks for the cookbook posting. I've bookmarked it. One more thing I would like to see added is a mention about the odd syntax required by Mozilla. This has tripped up more than a few people (including me).
| CSS3 (Opera browser) | Mozilla equivalent | WebKit equivalent |
| border-top-right-radius | -moz-border-radius-topright | -webkit-border-top-right-radius |
| border-bottom-right-radius | -moz-border-radius-bottomright | -webkit-border-bottom-right-radius |
| border-bottom-left-radius | -moz-border-radius-bottomleft | -webkit-border-bottom-left-radius |
| border-top-left-radius | -moz-border-radius-topleft | -webkit-border-top-left-radius |
| border-radius | -moz-border-radius | -webkit-border-radius |
Finally, re the .HTC hack from Google Code . It works when all corners in a division share the same value. But it fails miserably when they don't. Working example: http://alt-web.com/DEMOS/CSS-Rounded-Corners.shtml. IE users will see a normal box.
Nancy O.
Hi Nancy
I did not think to include the odd syntax for firefox as the version 4 should, (how often have we heard that) be standard compliant, but if you do not mind I will copy your usage table into the cookbook posting?
I have also just added a new link regarding a htc file that adds 2 more css3 properties, - http://fetchak.com/ie-css3/, and whilst this also uses vml, it does add better, (more stable) vml support and functionality to the older IE browsers, border-radius, (again only for all 4 corners) box-shadow and text-shadow. The last two could be done using IEFilters but as the use of IEFilters is even more complex/controversial than using vml, the inclusion of the link may help others when used with extensive testing, I will repeat for the non-professionals that may be reading this, test, test, and test again when using such items.
Paula
Hi Murray
No one ever said that rounded corners are simple, and just to prove it Mozilla decided to implement their own format
Anyway to change the subject slightly -
For those who may not already know, I did work for the dreaded evil empire, (Microsoft) a number of years ago and one of the people I know from then was a member of the team that developed vml, (he also helped write the specs submitted to the W3C for vml, and some IEFilters), so due to the debate on using vml for rounded corners I asked him his opinion, (I normally would not do so) and the opinion of a few others, (one is a developer on the webkit project), and here is a brief summing up.
From the vml developer - VML was developed to be used and script manipulated in a similar fashion to the canvas api and svg, and can be used quite safely for the creation of rounded corner graphics, but just like any other browser graphic drawing interface, (canvas and svg) the use should always be tested.
From the webkit developer - VML was in his opinion a better option than svg, and not using this when necessary would be like ignoring the html5 canvas completely because it produces undesirable results in some circumstances.
But both say, (as I have also pointed out in the article) if it works in your circumstances, use it, not to do so is like ignoring gif's because we can now use png's.
Paula
There isn't a work around for IE7/8 unless you use images. All the css/htc methods I tested WILL break down somewhere along the line depending entirely on how simple or complex the layout gets. The layout doesn't have to get that complex believe me.
Al is correct - use images otherwise youre in for a nightmare...you won't know when BUT htc method will interfere with some jquery scripts or vice versa. Its images until 7 and 8 are dead I'm afraid OR ignore 7/8 in favour of other browsers that use css (But that aint an option as far as I'm concerned)
Or just do a very simple layout but that really quite restrictive.
Good Morning Nancy
Are you saying that just by using these four lines I can get rounded corners ? I tried but nohing happened.
-moz-border-radius: 20px;
-webkit-border-radius: 20px;
-khtml-border-radius: 20px;
Are there other CSS properties hidden in a file ?
Thanks for your help, as always.
yenguru wrote:
Good Morning Nancy
Well you have to specifically apply them to something like:
#myBox {
-moz-border-radius: 5px;
-webkit-border-radius: 5px;
border-radius: 5px;
background-color: red;
color: #fff;
width: 200px;
height: 200px;
<div id="myBox">This box has rounded corners</div>
Supported by IE9 upwards and Firefox, Safari, Chrome
yenguru wrote:
Thanks osgood.
I was trying to make my whole page with rounded corners. So should I put it on my <head> section ?
Whole page? What do you mean by whole page?
If you want the outer four corners of your page to have rounded corners then you need to wrap the rest of the html content in a <div>
<div id="pageWrapper">
The rest of your html code (the bit which is inside the <body></body> tags) goes here.
</div>
Then style the pageWrapper
#pageWrapper {
Is that what you are trying to achieve?
yenguru wrote:
I see. Thanks my friend. Sorry for the trouble.
No trouble. To round the corners when using tables you will have to resort to the old method of using images. Any reason for using tables as a construction method, they are well passed their sell by date for building a website?
Actualy what I was trying to do was Nancy's example
The centre box has rounded corners. That's what I wanted to do. Here is the code that I used.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
<title></title>
<style type="text/css">
.BG {
background-color: #F0E8DB;
background-color: #000000;
border-bottom-color: #000000;
.style1 {font-family: Catull}
.style3 {
font-size: 18px;
font-family: Catull;
font-weight: bold;
.style4 {
font-family: Cambria;
font-size: 14px;
color: #663300;
</style>
</head>
<body><center>
<table width="1604" border="0" cellpadding="0" cellspacing="0" class="BG">
<!--DWLayoutTable-->
<tr>
<td width="290" height="31"> </td>
<td width="1003"> </td>
<td width="311"> </td>
</tr>
<tr>
<td height="367"> </td>
<td valign="top"><table width="100%" border="0" cellpadding="0" cellspacing="0" bgcolor="#00FF00">
<tr>
<td width="1003" height="367" valign="top"><!--DWLayoutEmptyCell--> </td>
</tr>
</table>
</td>
<td> </td>
</tr>
<tr>
<td height="1081"> </td>
<td> </td>
<td> </td>
</tr>
</table>
</center>
</body>
</html>
Have a look here http://compass-style.org/examples/compass/css3/border_radius/
To help you with SASS, have a look here http://pleysier.com.au/sass_article.php.
Note the rounded corners of the page.
As I said it wont work with tables only with <divs>. Example below:
<head>
<title></title>
.BG {
width: 500px;
height: 500px;
background-color: green;
margin: 0 auto;
padding: 20px;
color: #ffffff;
text-align: center;
</style>
</head>
<body>
<div class="BG">
</div>
</body>
</html>
I disagree with Osgood's statement that rounded borders only work on Div tags. Not true. You can style tables and even table cells with rounded borders. Here's how:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Rounded borders</title>
table.rounded {
width: 700px;
margin: 35px auto;
border: 4px solid coral;
background: yellow;
/**ROUNDED BORDERS**/
table.rounded td {
width: 50%;
padding: 12px;
background:#FFF;
border: 1px solid teal;
</style>
</head>
<body>
<table class="rounded" cellspacing="10">
<tr>
<td>table cell 1</td>
<td>table cell 2</td>
</tr>
<tr>
<td>table cell 3</td>
<td>table cell 4</td>
</tr>
</table>
</body>
</html>
Here's a screenshot:
Nancy O.
Hi Nancy,
great and many thanks!
An interesting phenomenon I found: my DW fed with your code does show rectangular shapes, when I use design view, in live view contrast to it, it works like a charm! Loaded up to my server, all is ok too!
My replica of your code can be used as a evidence. Here is the link:
http://www.hansgd.de/AdobTest/roundedCornerNan/roundedCornerNanNeu2013 02.php.
Hans-Günter
Hi Nancy,
I stand corrected, shows you how much I use tables!
Good to know though just in case I need to throw in a table of two somewhere along the way.
Edit: I think I was trying it with an image in the table cell, that would make a difference would'nt it? Would need to use it applied as a bg image, right?
I guess in that case you could combine the two:
.rounded, img {
-moz-border-radius: 10px;
-webkit-border-radius: 10px;
Interesting stuff, just shows you have to keep experimenting and exploring all possibilities.
Thanks nancy,
and of course I had no idea what these "vendor prefixes" are and maybe there are more people like me.
And so they may be interested to this blog (e.g.):
http://demosthenes.info/blog/217/CSS3-Vendor-Prefixes
Hans-Günter
North America
Asia Pacific
