"Before you can perform print-related tasks...,you need to install a printer"
Feb 21, 2011 11:30 AM
I have Windows XP SP3.  I am using Adobe Acrobat Pro 9.  I've never had a problem printing a pdf file before.  My printer is a year old and all other applications print without problems.  Suddenly, I am unable to print pdf's.  Any suggestions?
    Feb 21, 2011 1:21 PM   in reply to GoToJane
    Please  verify  if you're Acrobat 9  is updated to  9.4.2 by  checking the version at  Help > About Acrobat  9 Pro
    If  it  is Acrobat 9.4.2 then  do  the the  following....
    the fast and easy way:
    1.) go to the installation directory of Acrobat (C:\Program Files\Adobe\Acrobat 9.0\Acrobat)
    2.) Look for the file "Adobe.Acrobat.Dependencies.manifest"; do  a right click (open with)  then  select from the list  of programs -  choose Wordpad;
    3.) Delete the line <file name="atl.dll" /> then  click  on the Save button
    4.) Reboot your machine after saving that file
    This should fix the issue of being unable to print PDF file after installing 9.4.2 update for Adobe Acrobat.
    Feb 24, 2011 4:17 AM   in reply to joebert99@yahoo.com
    In addition to the above solution, you can also fix your problem by using the EXE as below. I applied the fix on my system, and it seems to have fixed my printing woes.
    You can download the EXE from:
    http://kb2.adobe.com/cps/891/cpsid_89178/attachments/AcrobatPatchAppli cation.exe
    For more information on the same, please refer to:
    http://kb2.adobe.com/cps/891/cpsid_89178.html (Solution 1 listed on the page)
    Regards
    Ankit
