smon_ed
Adding a TABSTOP character into a RichEditableText component
Feb 23, 2011 9:29 AM
I am placing html text, loaded from a database, into a RichEditableText component.
instance.textFlow = TextConverter.importToFlow(txtString, TextConverter.TEXT_FIELD_HTML_FORMAT);
The loaded text contains tab characters but they are not displaying.
I have tried to find a solution by saving my text to database with the tab characters replaced with a custom string like ~tab~
I then am using a search-and-replace function to replace all of the instances of ~tab~ with a tabstop character.
But I still can't get the character to display.  "\t" doesn't workand nor does anything else I have tried.
Any ideas what I can do to get the tabstops to display?  *confused*
    Feb 23, 2011 6:47 PM   in reply to smon_ed
    well you can use something
    like
    in this part of the code im looking for "$" and "," within my string.
    public var myPattern:RegExp = /[$,]/gi;
    then on you string you need to do something like this.
    mx.utils.StringUtil.trim(fields[0]).replace(myPattern,"");
    i'm replacing every occurrence with a blank. but you can replace your occurrences with "~tab~ " if thats what you wish to do.
    Hope this helps.
    Miguel
    Nov 19, 2012 7:40 AM   in reply to smon_ed
    hello I have the same problem !
