Hello Guys
I have a htmlText Field, and I wanna embed a Movieclip from my library into the text.
I've tried everything for about 5 hours, nothing worked, even though the Adobe Help stated that it's possible:
src: Specifies the URL to an image or SWF file, or the linkage identifier for a movie clip symbol in the library. This attribute is required; all other attributes are optional. External files (JPEG, GIF, PNG, and SWF files) do not show until they are downloaded completely.
So you can stick images from your library in html textFields... the question is how?
Thank you in advance.
Kenji
*bump* please help me.
var tf:TextField= new TextField()
tf.width=700
tf.height=300
tf.htmlText=" <img src='me.png'>"
addChild(tf)
replace me.png with an image you have in the same location as your swf
There seems to be a bug that the <src needs a character before it to display
"_<scr...
For a symbol just replace me.png with the linkage name Symbol1 or whatever
Can you show what you tried already? I would have said it can't be done, but if the docs are correct (they rarely aren't, but it happens) then you should have been able to use a linkage that you specify for the library object. Did you specify a linkage?
you can't specify a linkage id with as3 - use the class:
tf.htmlText="<img src='YourClass' />";
Well, I was using the linkage and everything correctly. I found out my fault. I was using a TLF-Textfield which doesn't support the embedding of library images (or does it??)
It works in classic textfields though, but in classic textfields, the textflow is totally broken with images. Instead of inserting it into the textline, it creates a new line, only for the picture. But for my purpose (chat smileys) that's of no use. I need my pictures right in the text line where they have to be...
Like <-- this.
And not like <--- this, as it is with classic textfields.
Does anyone know how to embed library movieclips into a TLF-Text??
Of Course you can use a linkage ID. That stands for the idendification of the link, hence where you assign a class.
